3 Pre-Installation Task
Before you upgrade or install the FM Suite, perform the following tasks:
Apply critical security patches to the operating system.
Apply critical security patches to the database server application.
Acquire Secure Sockets Layer (SSL) compliant security certificate from Certification Authority.
Read and understand the Security Overview in Oracle Hospitality Cruise Fleet Management Security Guide.
Microsoft .Net Framework Version
To verify if you have the required .Net version, perform
the following steps:
- You have to execute the below statement in the command
prompt (CMD).reg query
"HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\full" /vversion - If it displays the version less than 4.6.1, you need to download the .Net Framework 4.6.1 version.
