2 Prerequisites
This topic explains the prerequisites for Fleet Management System (FMS) installation and upgrade.
Below are the minimum system requirements for each server type. We strongly recommend that you refer to the Cruise Compatibility Matrix at Oracle Help Center for the latest supported Operating System and Database version.
Database Server
Operating System: Microsoft Windows Server 2016
Memory: 16GB of RAM, 1 TB of disk space
Oracle Database Client version: Oracle Database 32-bit Full Client for 19c including the ODAC
Oracle Database version: Oracle Database Server 19c / Oracle Database 32-bit Full Client for 19c including the ODAC
Database Configuration:
The Database character set can be set to Western or Unicode. However, you must ensure that SPMS and FMS Database character set are configured the same to avoid data discrepancy. For example, if the character set is set as UTF8 in SPMS Database, then it must be the same in FMS Database.
Similarly, the Database table column type must be configured the same in both the SPMS and FMS. For example, if the type NVARCHAR is used, then both the SPMS Database and FMS Database must be the same.
- Additionally, the data type and length of Database table columns in which data is to be transferred from/to must be the same between FMS and SPMS.
Internet Information Services (IIS) Web Server
Memory: 16GB of RAM, 512GB of disk space
Microsoft .Net Framework: Version 4.6.1. See Microsoft .Net Framework Version for more information.
FMS Application Client
Operating System: Microsoft Windows 10
Microsoft .Net Framework: Version 4.6.1, see Microsoft .Net Framework Version.
Java Runtime Environment (JRE): Version 8
Crystal Report Runtime: SAP Crystal Report runtime engine for .NET Framework (32-bits) version 13.0.33 is installed on the target machine. See How to Install/ Upgrade Crystal Reports runtime engine for .NET Framework (32-bit) for further information.
Network
All the FMS Sender / Receiver host machines must be in same domain when transferring the data over MSMQ with the Active Directory integration.
The IIS Server machine and the FMS Client machine also must be on the same domain to authenticate the login credentials in Active Directory login mode.
