Internet Information Services (IIS) Set Up
The following sections describe the steps to set up IIS.
Setting Up IIS on Microsoft Windows Server 2016 and above
- In the Start page, select Server Manager.
- Select Add roles and features.
- In the Before You Begin screen, click Next.
- In the Select Installation Type screen, select Role-based or feature-based installation and click Next.
- Click Select a server from the server pool with the current machine selected, and click Next.
- In the Select Server Roles screen, check Web Server (IIS). If a new window opens and prompt additional features are required, click Add Features to install, and then click Next.
- Click Next.
- Read the IIS information, and then click Next.
- Click Next to install the defaults.
- In the Confirm screen, review the install items, and click Install.
- Once the set up is complete, click the Close button.
- To verify that the web server has been installed correctly, at the browser address bar, type http://localhost.The default website opens and displays the IIS image.
- Run FM Suite and select OHCFMSSecurityService as an added component to install onto the machine. A folder is created automatically with the same name OHCFMSSecurityService under C:\inetpub\wwwroot folder.
