3 The FMS Login Screen
Figure 3-1 The FMS login screen
Login Screen for FMS Applications contains following fields:
Login: FMS user name.
Password: FMS password.
TNS Names File: Location for tnsnames.ora on user’s system.
Data Source: Connect to the correct data source.
Once you are validated, the Connection Key Manager screen appears for you to select a default schema. If you have selected a default schema earlier, the TNS Names file and Data Source are pre-filled with the user login after the validation application is launched.
Figure 3-2 The AD Login
Login: AD user name.
Password: Domain password.
Once you are validated, the Connection Key Manager screen appears for you to select a default schema. If you have selected a schema earlier, the TNS Names file and Data Source are pre-filled with the user login after the validation application is launched.
To enable Active directory set “IsActiveDirEnabled” flag in App.config to “Y”
<appSettings>
<add key="IsActiveDirEnabled" value="Y">
</appSettings>Connection Key Manager for FMS Desktop applications:
Figure 3-3 Connection Key Manager
You are required to select a Schema from the grid and TNS Names Files will pre- populate to the login screen and it is non-editable. To start the application, click Apply.
Connection Key Manager for Sender/Receiver:
Figure 3-4 Connection Key Manager for Sender/Receiver
The selected Default schema, Data Source and TNS Names Files will pre-populate on login screen and are non-editable. To start the application, click Apply.
In the Connection Key Manager window, you can also configure the SMTP details and General Settings for Sender / Receiver
