Language Template
The Language Template option enables you to configure the languages needed for the questionnaire template, and the Questionnaire page in the Check-In application.
The Language Template option can be found in the Administration, Enterprise, Language Template menu.
Search and Enable the Language
Figure 4-9 Language Template
This figure shows the Language Template
  1. Navigate to the Language Template option where the system displays all language records from the database with disabled status on first time setup.
  2. To search for the language, enter the language name or language code at the search field and click the Search button.
  3. If no matching record is found, the system displays the message “No data to display.”
  4. To enable or disable the language, toggle the Status button of the language that you want, and the system displays the notification, “Language updated successfully.”
  5. To view the enabled language record, deselect the Show Inactive checkbox.
