8 Guardian
The Guardian page is only visible when the guest is a minor, allowing you to assign one or more guardians to the minor. This page is hidden for guest with age above the defined minor age. You can use one of these options to search for a guardian:
  • Manual Search: Search for a guardian profile by entering the First Name, Last Name, and other relevant information. The search criteria fields watermark is setup in Check-In – Search Template setup.
  • Scanning RFID Card: Search for guardians using their RFID cards. See section Search by Scanning RFID Cards
  • Travel With: Retrieves all guest profiles that have the same booking or stateroom number.
Figure 8-1 Search and Add Guardian Page
This figure shows the Search and Add Guardian page
To add a guardian, select the guardian profile using the +Add button from the returned result page or scan the guardian RFID card. See section Search by Scanning RFID Cards
Figure 8-2 Assigned Guardian List
This figure list the Guardian assigned to the minor.
To remove a guardian, in the Guardian section, select the guardian profile and then click the X of the selected profile.
Once you have confirmed the Guardian Information, click Next to complete the Guardian page.
