Export Safety Setup
This function exports all of the Safety setup from one ship to another. We recommend that you to use this tool with the new Muster List, In Port Manning, and Safety Drill setup.
Figure 14-12 Export Safety Setup
In the Tools Import/Export tab, select Export Safety Setup from the ribbon bar.
In Export Safety Setup window, select the desired Safety setup and then click Export to export. Files are exported to
C:\Users\Public\Documents\Oracle Hospitality Cruise\SafetySetup_v8.xxx_yyymmdd.xml.’
