Verify Encrypted Database Data
The Verify Database Encrypted Data function verifies the encrypted data and confirms that encryption can be change before performing the Change Encryption Key.
In the Tools application, select Verify Database Encrypted Data from the ribbon bar.
In the Verify Encrypted Data window, click Verify.
The Verify Database Encryption Data verifies data in the User login credentials, Parameter, Reservation, POS Information, (PGP Key), Credit Card Registration, Transfer, and Authorization
If the verification returns a failed message, possibility due to invalid data, correct the error and repeat the process.
Figure 14-5 Verify Encrypted Database
Click Close when the process finishes.
