Assigning IPM Group
Figure 7-123 IPM Setup
This figure shows the IPM Setup
Table 7-28 Field Description of IPM Setup Window
Field Description
IPM Groups/Functions
List of available IPM Groups.
Assigned
Indication of IPM Group currently assigned if checkbox is ticked.
IPM/Safety Role
Defines the Safety Department the IPM Group belongs to.
Occurrence Required
Occurrence based on selected port and IPM Group.
Port Only: Belongs to specific Safety Department Occurrence at Port.
Tender Only: Belongs to specific Safety Department Occurrence at Tender Port.
Port/Tender: IPM Group applicable to both type of port.
Required
Define the number of required crew member(s) to remain onboard to perform the safety function and this may be overwritten. This value takes precedence if no value is define in % Required of The Group.
Define the minimum number of crew onboard by percentage. If the number of crew in the group changes, the required crew onboard changes automatically based on the percentage specified. For example, a safety group with 20 crew members and percentage is set to 50%, the required crew is 10.
  1. From the Safety Menu, select In Port Manning Setup from the drop-down list.
  2. Navigate to the IPM Setup tab and select the Occurrence Required and Safety Department.
  3. Select the In Port Manning Groups/Functions and click the right arrow.
  4. In the Required or % Required of the Group Field, enter the desire value.
  5. Use the Search function to search for the IPM Group. The search field is case sensitive.
