PreviousNext
JavaScript must be enabled to correctly display this content
Deleting Existing Routing
To remove routing setup in the crew account,
In the Disc, Route, Pkg, Routing tab, select either to
delete the sub-financial department code from
the individual assignment, or select the Main Financial
Department to delete all department codes, then click Delete Routing.
The system prompts for confirmation to delete the assignment.
Click Yes to confirm the deletion or No to return to the Routing window.
SPMS Discount
The SPMS Discount
function allows you to assign eligible discount either by percentage
or value to a crew account.
