Group Lookup
  1. On the Home screen, press the Group Lookup button.
  2. In the Guest Lookup screen, at the bottom, select the type of group status such as Checked In, Expected, Checked Out or All.
  3. In the search bar, enter the group name or ID.
  4. To view the group information, select the group name from the result list.
  5. Press the Group Name on the Group Information screen to display the cruise details.
  6. Press the Group Members option to display the member names and the cabin numbers.
  7. Select a member name or cabin number to display the booking and personal information.
  8. Press Edit at the Information screen to edit the booking information.
  9. To view other information such as Group Discount, Group Routing and Group Invoice, select the option in the More Information section.
