PreviousNext
JavaScript must be enabled to correctly display this content
Add Posting
Add Posting allows you to post and/or manually adjust a
charge.
Retrieve the guest account from the Search panel, then
click Add Posting in the Guest Handling window.
At the Add Postings from, select the Financial
Department from the drop-down list or use the Search option
for a department code.
Figure 10-50 Add Posting Financial Department Selection
Insert the Value, Check Number and
select the Invoice number to post, then click Add. This transfers the posting to the Posting
List, enabling you to post more than one charge.
Figure 10-51 Adding a Charge
Item count increases automatically when the posting is
more than one.
Figure 10-52 Add Posting Count
Click Post to finalize the posting(s).
Posting will appear in the Invoice tab, among other posted
charges.
