POS Discount Eligibility Setup
Figure 23-3 POS Discount Eligibility Setup
This figure shows the POS Discount Eligibility Setup
  1. From the Administration, POS Discount menu, select POS Discount Eligibility Setup.
  2. In the POS Discount Eligibility Setup window, click Add New on the ribbon bar.
  3. In the Group field, select a group from the drop-down list.
  4. Enter the code and the name.
  5. Go to the MICROS Object Type section and select one of the following options; 0 = None, 1 = Menu, 2= Major Group, or 3 = Family Group
  6. Select the respective item from the MICROS Object number drop-down list or click the Binocular icon to search.
  7. To enter more menu items, repeat the steps above.
  8. Click Apply to save.
