POS Discount Level Setup
The POS Discount Level Setup is the first set of configurations for the POS Discount, defining the discount group to be used in POS Discount Rate Setup.
Figure 23-2 POS Discount Level Setup
From the Administration, POS Discount menu, select POS Discount Level Setup.
Right-click and select Add New in the POS Discount Level Setup window.
Enter a code, a description, and any comments in the Description and Comments fields.
Click Apply to save and OK to exit.
Repeat the steps above to enter more discounts.
