Recent Movement
The Recent Movement section providing the Security Offices an overview of people who passes through the gangway/tender successfully.
  • When viewing on screens with a resolution of 412px or 360px, records are showed in a list format. On screens with a resolution above 600px, records are showed as tiles arranged from left to right.
  • The system shows up to 10 tiles at a time for easy navigation. To change the number of tiles shown, use the parameter value in Gangway –Number of recent movement show.
  • You can also search for the movement history using the following steps:
    • Select the recent movement tile.
    • A profile’s movement history drawer opens from the right. (See Movement History for more information).
Recent Movement Page – Horizontal View
Recent Movement Page – Vertical view
Recent Movement Page – Vertical View
Recent Movement History
