Business Events
In the context of Gaming Integration with Light & Wonder, business events are used to send both profile updates and reservation notifications to L&W from OPERA Cloud.
Please configure the below business events in OPERA Cloud in order to have these operations working. For details on configuring business events, refer to Configuring Business Events in the OPERA Cloud services documentation.
Profiles
Use the below details to create business events for OPERA Cloud Profiles.
  • Property: Select your OPERA Cloud property.
  • External System: Select the external system with the same name as the Outbound Configuration you previously created.
  • Module: Select PROFILE.
  • Business Event: Select UPDATE PROFILE.
  • Data Elements: Select all available data elements.
  • Conditions:
    • MEMBERSHIP NUMBER IS NOT NULL
    • MEMBERSHIP TYPE = 'PTS' (the Membership Type setup in OPERA Cloud)
    • Ensure these conditions are used as ‘AND’ (do not use ‘OR’)
This image shows the Business Events Configuration screen for business event UPDATE PROFILE.
This image shows the Business Events Configuration Search screen.
