7 Assigning Properties to Custom Templates
Prerequisites for Assigning Properties to Custom Templates
Once custom templates are configured, you must associate a custom template with properties in order to distribute configuration. All properties provisioned for your enterprise are listed.
Once configuration has been distributed to the property, the template assigned to a property cannot be changed.
Tip:
Use the Unassigned/Assigned filter options to assist with searching for properties.
  1. From the Side menu, select Manage Properties.
  2. Enter search criteria and select the Unassigned filter.
  3. Select check boxes for properties in the search result, then click Assign Template.
    1. Enter search criteria for the custom template.
    2. Select a template in the search result, then click Assign.
Unassigning Properties from Custom Templates
The assigned template for a property can be removed if the configuration has not been distributed.
  1. From the Side Menu, select Manage Properties.
  2. Enter search criteria and select the Assigned filter.
    1. Select the property, then click ManageManage Configuration icon
