Calling Oracle Hospitality Distribution APIs
Environments and Base URLs
Use the following base URLs for Oracle Hospitality Distribution APIs. With Distribution API, one single endpoint for production and one single endpoint for non-production can be used to reach any property in the world (that has enabled your channel) using OPERA Cloud Distribution. Based on your location, you may decide to use one region to connect to all properties. If you are trying to minimize some potential latency, you may also decide to assign properties to one of the two regions based on property location.
Production Region URLs
- Production Base URL North America: https://ohd-up.hospitality-api.us-ashburn-1.ocs.oraclecloud.com
- Production Base URL Europe: https://ohd-up.hospitality-api.eu-frankfurt-1.ocs.oraclecloud.com
Non-Production Region URLs
- Non-Production Base URL North America: https://ohd-uat-up.hospitality-api.us-ashburn-1.ocs.oc-test.com
- Non-Production Base URL Europe: https://ohd-uat-up.hospitality-api.eu-frankfurt-1.ocs.oc-test.com
Confirm your internal network allow-lists, certificates, and TLS requirements for each environment before testing.Required Headers
Include the following headers with every request:
- Authorization: Bearer {OAuthAccessToken}
- Obtain the OAuth access token from the Oracle Distribution Authentication API.
- x-channelCode: {ChannelCode}
- Channel code provided by Oracle.
- x-app-key: {ApplicationKey}
- A unique application key generated when you register your application in the Oracle Hospitality Developer Portal. See Viewing the Application Key.
Example Request
POST {BaseURL}/content/v1/hotels
Headers:
- Content-Type: application/json
Additional References
- For a complete list of Oracle Hospitality Distribution APIs, see Oracle Distribution APIs collection. https://github.com/oracle/hospitality-api-docs/tree/main/postman-collections/distribution
- For authentication details, see Oracle Distribution Authentication API.
- Ensure your use of external systems and tools aligns with Oracle security, privacy, and compliance guidelines.
