Common HTTP Errors and Messages
Common error codes produced by Oracle Hospitality APIs are listed in the following table.
For a complete list of OPERA Cloud REST API error codes, refer to the Web Service Error Codes topic.
Table 8-7 Common HTTP Error Messages
| Error Status | Error Response Body | How to Resolve |
400 |
Response body details which fields are at fault. |
Change the fields mentioned in the error response, such that they align with the specifications; referencing the swagger spec will help here. In some cases the values are determined by a (hotel specific) configured List of Values (LOV), so ensure you supply a value that is in the LOV for that hotel; the List Of Values Oracle Hospitality APIs will help here. |
400 |
This API is not supported for the current database version. |
Contact Oracle Customer Support at the Customer Support Portal stating the gateway being called and the error message received. |
401 |
No response body |
Ensure your oAuth token is valid and latest. Also, ensure your Application Key is valid. Check it by Viewing the Application Key |
402 |
"invalid_grant", "[Wrong Password]" |
Check the password of the integration user. See Changing Your Integration User Password for more information. |
403 |
Unauthorized to access the resource |
This could be caused by the integration user missing the WSACCESS role. Ensure the environment owner has approved the integration user. This could also occur if you are sending the wrong hotelId. Ensure the hotel ID being sent in the x-hotelid header matches a hotel in the environment being called. In recently migrated environments secured by Client Credentials authentication (OPERA Cloud Identity Management), ensure you are using the reissued clientId and clientSecret, not the pre-migration clientId and clientSecret. |
403 |
No response body |
Ensure your oAuth token is valid and up to date. Re-request it by using Authenticating to Oracle Hospitality Property APIs. Also ensure your integration user in OPERA Cloud Services has access to the property (hotel) you supplied in the "x-hotelid" header. |
403 |
No Subscribed Plan or API found |
This occurs when accessing an API to which you do not have access. If this is an early adopter (v0) API and you think you
already have access to the Early Adopter API Program, check that the
application specified in the x-app-key header has access to the Early
Adopter APIs by following this process:
If you have not yet called the v0 APIs but would like to, contact us as explained in the Early Adopter API Program. If this is a Distribution API, you must register in the Developer Portal to use the API. Verify that the AppKey you are using corresponds to the correct environment (Non-Production or Production). An AppKey from one environment cannot be used to call APIs in the other. |
403 |
Forbidden |
This can occur if IP Allow Listing is enabled and your IP address is not configured for access. When enabled, a message appears in the Developer Portal under Environment Details. Verify your IP address and provide it to the customer for inclusion. |
404 |
No response body |
If you are calling an Asynchronous API: Once you have sent the final GET call to obtain the results of the async processing, the data is no longer available on the same summaryId, so you will receive a 404 error. To retrieve the data again, you must restart the request sequence at step one. |
404 |
OPICS-NOT_FOUND |
Contact the environment owner to verify that Oracle Payment Interface Cloud Service has been set up by checking for product ID 14308 and ensuring that Token Exchange Service is selected. Customers can contact Oracle Consulting or a reseller to configure Oracle Payment Interface Cloud as needed. |
405 |
No response body |
Ensure the HTTP verb you are using is supported by the Oracle Hospitality APIs by checking the Oracle Hospitality APIs documentation. |
406 |
No response body |
Set your "accept" header to "application/json" as the Oracle Hospitality APIs will produce only "application/json". |
413 |
No response body |
Ensure your request matches the documented request body schema. If your scenario requires "bulk" fetch or update then consider the jobbed Oracle Hospitality APIs. |
414 |
No response body |
Consider whether you need to specify all the query parameters being specified; there may be more efficient resources or ways to structure your query. |
415 |
Unsupported Media Type |
Ensure your request payload has a content-type of "application/json". |
500 |
Response body details the error. |
Try your request again in a few moments or contact Oracle Customer Support at the Customer Support Portal. |
502 |
No response body |
503 |
No response body |
