Assigning Roles to Users
Non-Federated OPERA Cloud Identity Management Customers
The following roles are available for OCIM Customers. These roles allow customers to assign their users to one or more roles.
  • OHIPADMIN
  • OHIPDEVELOPER
  • OHIPANALYTICS
  • OHIPENVIRONMENTS
  • OHIPVIEW
  • DEVELOPERPORTALACCESS (will be deprecated in future)
Table 2-1 Application Roles
OHIPADMIN OHIPDEVELOPER OHIPANALYTICS OHIPENVIRONMENTS OHIPVIEW DEVELOPERPORTALACCESS
API Documentation
View
View
No Access
No Access
View
View
Applications
View-Add-Edit-Delete
No Access
View
View
Application Key
View-Reissue-Copy
View-Reissue-Copy
No Access
No Access
No Access
View-Reissue-Copy
Environment
View-Add-Remove
View
No Access
View-Add-Remove
View
View-Add-Remove
API Analytics
View
View
View
No Access
View
View
Client Secret
Read-Issue
Read
No Access
Read-Issue
No Access
Issue (View Only at time of reissue)
Approve Partner Connections (Includes module and Property Level Access)
Yes
No Access
No Access
Yes
No Access
Yes
Approve Streaming Applications (Within Applications)
Yes
No Access
No Access
Yes
No Access
Yes
For details on how to assign group membership to users in Non-Federated OPERA Cloud Identity Management, refer to Assigning and Removing Group Membership in the OPERA Cloud Identity Management Administrator Guide.
To access the Developer Portal, identity administrators must first create a Custom Group for OHIP at a chain level (<Chain Code>-DEVELOPERPORTALACCESS, <Chain Code>-OHIPADMIN, <Chain Code>-OHIPDEVELOPER, <Chain Code>-OHIPANALYTICS, <Chain Code>-OHIPENVIRONMENTS, <Chain Code>-OHIPVIEW) in their respective identity provider. For more details on Custom groups, refer to OPERA Cloud Identity Management Seeded Groups in the Identity Federation Overview guide.
Once the Custom group for OHIP is created at a chain level, administrators must assign the users to this custom group in their respective identity provider.
Users must be chain-level users to be granted DEVELOPERPORTALACCESS, OHIPADMIN, OHIPDEVELOPER, OHIPANALYTICS, OHIPENVIRONMENTS, and OHIPVIEW group membership and to successfully access the Developer Portal.
Developer Portal users do not have the ability to call APIs.
