Assigning Users to Roles
Application Roles
Refer to the table below for the application roles that are available.
OHIPADMIN OHIPDEVELOPER OHIPANALYTICS OHIPENVIRONMENTS OHIPVIEW APPLICATIONDEVELOPER
API Documentation
View
View
No Access
No Access
View
View
Applications
View-Add-Edit-Delete
No Access
View
View
Application Key
View-Reissue-Copy
View-Reissue-Copy
No Access
No Access
No Access
View-Reissue-Copy
Environment
View-Add-Remove
View
No Access
View-Add-Remove
View
View-Add-Remove
API Analytics
View
View
View
No Access
View
View
Client Secret
Read-Issue
Read
No Access
Read-Issue
No Access
Issue (View Only at time of reissue)
Approve Partner Connections (Includes module and Property Level Access)
Yes
No Access
No Access
Yes
No Access
Yes
Approve Streaming Applications (Within Applications)
Yes
No Access
No Access
Yes
No Access
Yes
  1. In Oracle Identity Cloud Service, select the Oracle Cloud Services menu from the left-side panel.
    This image shows Oracle Identity Cloud Service screen
  2. Select HospitalityDeveloperPortal.
    This image shows the HospitalityDeveloperPortal.
  3. Select the Application roles tab in HospitalityDeveloperPortal. Refer to the 'Application Roles' table above for more information on the available roles.
    This image shows the HospitalityDeveloperPortal and the app details.
    This image shows the Application Roles tab.
  4. Click the menu present for the ApplicationDeveloper role and click Assign Users.
    This image shows the Assign Users selection.
  5. On the Assign Users screen, select the users to assign the role and click OK.
    This image shows the screen to assign users to roles.
  6. For newly created Role Based Access Control (RBAC) roles, such as OHIPADMIN, OHIPDEVELOPER, OHIPENVIRONMENTS, OHIPANALYTICS, and OHIPVIEW, follow steps 1 to 3.
  7. Click the side menu present for any one of the application roles (for example, OHIPADMIN) and click Assign User.
    This image shows the roles listed under the Application Roles tab.
  8. On the Assign Users screen, select the users to assign the role and click OK.
    This image shows the OK button to assign a user.
