Block Wash Schedules
By using a Block Wash Schedule it possible to automatically reduce the number of rooms in a Block by either a percentage or a fixed amount at a specific schedule.
Block Wash templates allow you to configure wash schedule codes and a wash schedule. A wash code can then be selected when setting up a wash schedule for a specific Block to automate the setup of the wash schedule. See Managing Block Wash Schedule.
Parent topic: Block Management Overview
