Configuring Electronic Registration Card Templates
In multi-property operations (Multi Property OPERA Control is active), you can copy registration card templates to other properties.
In multi-language operations (Multi-language OPERA Control is active), you can copy templates to other language(s).
Adding Templates
From the Administration menu, select Enterprise, select Chain and Property Management, and select Electronic Registration Card.
Click New.
Enter or select the property or properties. You can select multiple properties when your session is initialized from a Hub location.
Enter or select the Language(s) if multi language control is enabled.
Enter or select the membership type(s).
Select Rich Text to use the WYSIWYG Editor or select Source to view and edit HTML source code.
Add or paste (CTRL+V) text and then format the text according to your needs. For more information, see Using the Rich Text Editor.
- Click Save.
Previewing Templates
Select or confirm the Property, enter optional search criteria, and click Search.
From search results, select the row level vertical ellipsis of the template and select Preview.
Click the X to close the preview.
Editing Templates
From search results, select the row level vertical ellipsis of the template and select Edit.
Make the desired changes. For more information, see Using the Rich Text Editor
To delete a merge code, place cursor in front or behind the Merge Code and click either the delete key or the backspace key. -
Click Save.
Copying Templates
You can copy (clone) templates to current or other properties, other languages, and/or membership types as needed. As part of the copy process you can customize the layout of the new template(s), for example, copy the layout, update the boilerplate text, and change to a different language in the new template.
From search results, select the row level vertical ellipsis of the template and select Copy.
In the Target Electronic Registration Card Details section, select the destination property, the language of the new template, and a Membership Type.
Make required changes by editing text, merge codes, images.
Click Save.
Deleting Templates
From search results, select the row level vertical ellipsis of the template and select Delete.
Click Delete to confirm.
Parent topic: Chain and Property Management
