Modify/Update Block — Delete Block
Deleting a block removes all reference to the block, which
is useful for any data entry or duplication errors. Only users with
the Delete Block task assigned to their roles can delete blocks. You
will not be able to delete the block if there are active reservations
associated with the block; cancel these reservations or remove
the block code from the reservations. For more information, see: Editing a Reservation.
Deleting a Block
- From the OPERA Cloud menu, select Booking, select Blocks, and then select Manage Blocks.
- Enter search criteria and click Search.
- Select a block in the search results, click I Want To . . . and select Delete Block.
- Click Yes to confirm.
Parent topic: Blocks
