Products and Product Benefit Specifications
Benefit plans come in many variations, where part of the plan is common across plans, and part is specific to the account for which the plan is designed. In Claims a benefit plan for which all options have been defined is called a product. In other words, a product is the complete package of configuration needed to adjudicate claims,including all benefit options and cost-share settings.
The Claims data model can be characterized as fairly flat; it is a four level structure where the top level is the product, and the bottom level is the coverage regime.
Product
A product uniquely identifies a set of benefits. A product has the following fields:
Product Fields Table
Table 1. Product Fields Table
Field Description
Code
The unique code of the product.
Description
The description of the product.
Aggregation Level
A label that drives whether or not a limit is shared across products.[1]
Priority
In the event that a person or object is subscribed to multiple products, the priority (number) determines in which order the products are evaluated. Products are evaluated starting with the smallest priority number value, e.g, a product with priority 1 is evaluated before a product with priority 2.
Brand
The brand to which the product belongs.
Product Line
The product line to which the product belongs (e.g. HMO, PPO, POS).
Product Family
The product family to which the product belongs.
Funding Arrangement
The funding arrangement of the product (e.g. self insured, fully insured, partially self insured).
Claim Time Limit
The length of the period allowed between the service date and the receipt date of a claim, for claims covered by this product.
Claim Time Limit UoM
The unit of measurement in which the period is expressed: Days, Months or Years.
Currency
The currency for amount fields in product limits, product benefit specification values and product benefit specification limits.
Build Number
Integer that is incremented by 1 for each successful build
Constraints:
  • Claim time limit and claim time limit UoM must both be specified or both be left blank
Underwriters
An underwriter is an organization that carries the financial risk for a product. Configuring underwrites is optional; there is no hard coded logic in the application that requires underwriters to be set up for a product. The purpose of storing underwriters is to support the scenario where the application enriches claim transactions with underwriter information to be leveraged downstream.
A product can have no, one or multiple underwriters associated with it. An underwriter has the following fields:
Underwriter
Table 2. Underwriter
Field Description
Organization
The organization that carries the risk for the specified product.
Product
The product for which the risk is carried.
Percentage
The percentage of the risk carried.
Start Date
The first day of the period in which the relation acts as an underwriter for the product.
End Date
The last day of the period in which the relation acts as an underwriter for the product.
Constraints:
  • It is not allowed to specify multiple underwriters for the same organization that overlap in time
  • At any given point in time, a product has no underwriters OR the total of underwriter percentages for one product is 100
  • The end date of the underwriter should not lie past the end date of the organization
Underwriters have no functional impact on calculating a claim’s benefits.
Financial Holds
Financial holds prevent financial transactions that include products to which the hold applies from being included in financial messages (and therefore paid).
A product can have no, one or multiple financial holds associated with it. A financial hold has the following fields:
Financial Hold
Table 3. Financial Hold
Field Description
Hold Type
The hold type that is applied to the product. Hold types are user defined and can be picked from a list of values.
Product
The product to which the hold applies.
Status
Active, Released or Expired.
Held By
The user that applied the financial hold to the product.
Hold Datetime
The date and time the financial hold was recorded in the system.
Released By
The user that (manually) released the financial hold from the product.
Release Datetime
The date and time the financial hold was released.
Expiration Datetime
The date and time the financial hold expires automatically
Hold comment
A comment on why the financial hold was recorded on the product
Release comment
A comment on why the financial hold was released
Constraints:
  • Financial hold attributes can only be updated when the status of the hold is Active
  • Only expiration datetime, hold comment and release comment are updateable (as long as the status is Active)
  • Financial holds cannot be deleted
  • The expiration datetime of the financial hold should not lie in the past
Financial holds have no functional impact on calculating a claim’s benefits or the claims finalization process.
Financial holds on product level apply to all financial transactions with at least one financial transaction detail with a Product Code of a product that is on hold. As a consequence, customers that wish to use product financial holds need to make sure that the product code on financial transaction detail is propagated through dynamic logic (from claim line transaction coverage).
Product Provider Groups
Product provider groups represent the network of providers associated with a product. A product can be associated with no, one or multiple product provider groups. A product provider group has the following fields:
Table 4. Product Provider Group
Field Description
Product
The unique code of the product for which the product provider groups are defined.
Provider Group
The provider group that represents the list of providers that are affiliated with the specified product.
Assignment Label
The qualifying label for the assignment of the provider group. If specified the system will use the policy product provider group(s) with a matching assignment label when determining network status in the claims flow.
Start Date
The start date as of when the providers in
- the provider group (on this record)
- or the provider groups that match the assignment label during claims proccessing
are 'in network' for the product.
End Date
The end date of the product provider group.
Constraints:
  • It is not allowed to specify multiple product provider groups for the same provider group and assignment label that overlap in time
  • At least one of provider group and assignment label must be specified
Product provider groups work in conjunction with the benefit specification field "product provider group scope". To clarify, consider a scenario where a user configures two benefit specifications. Both have different benefits. The first applies only to claim lines for which the benefits provider is IN scope of at least one of the product provider groups, the second applies only when the benefits provider is OUT of scope for all of the product provider groups.
The start and end date are evaluated during claims processing, based on the claim line start date.
Product Limits
A product limit allows a user to set a value for a limit. This applies in the situation where the coverage regime(s) specify a limit (such as a deductible) without specifying the actual height. The product limit sets the height of that limit in context of the product, e.g., for product ABC the height of the deductible is set to 1500 dollars. In other words, the coverage regime acts as a template; the actual value is specified on the product limit. The merit of such a configuration setup is that the coverage regime(s) can be reused across all products. A product limit has the following fields:
Product Limit
Table 5. Product Limit
Field Description
Product
The unique code of the product for which the product limits are defined.
Limit
The limit that will be used by all regimes with cover withhold rules that count towards the limit.
Maximum Amount
The height against which the limit should adjudicate.
Maximum Amount Currency
The currency of the maximum amount; it is automatically set to the currency that is specified on the product.
Maximum Number of Units
Maximum Service Days
(Renewal) Reference
The way the renewal date is defined: 1st day of calendar year © or of plan year (P) or 1st of annual year start month (A)
Renewal Period
The length of the renewal period.
Renewal Period UoM
The unit of measure for the renewal period: Days, Months or Years.
Carry Over Period
The length of the carry over period.
Carry Over Period UoM
The unit of measure for the carry over period: Days, Months or Years.
Other Products Carry Over Period
The length of the other products carry over period.
Other Products Carry Over Period UoM
The unit of measure for the other products carry over period: Days, Months or Years.
Annual Year Start Month
The limit with the reference Annual starts on 1st of the month. This is only applicable for the limits with reference Annual.
Start Date
The start date of the period for which the limit will be applied. Evaluated against the claim line service date.
End Date
The end date of the period for which the limit will be applied. Evaluated against the claim line service date.
To clarify this concept, consider the following scenario. A payer offers a selection of three products; product A, B and C. These products are identical except for the fact that the height of the insurable entity deductible is different:
  • Product A has a $1000 insurable entity deductible;
  • Product B has a $1500 insurable entity deductible;
  • Product C has a $2000 insurable entity deductible.
Constraints:
  • It is not allowed to specify multiple product limits for the same limit that overlap in time
  • The product limit must specify a maximum that complies with the limit type
  • The product limit must either specify:
    • reference, renewal period and renewal period unit of measure
    • reference, renewal period, renewal period unit of measure, carry over period and carry over period unit of measure
    • reference, renewal period, renewal period unit of measure, other products carry over period and other products carry over period unit of measure
    • renewal reference, renewal period, renewal period unit of measure, carry over period, carry over period unit of measure, other products carry over period and other products carry over period unit of measure
    • none of the above
  • It is not allowed to specify a reference on the product limit level for limits that are not calendar year or plan year based
A benefit specification can be linked to one or more products in a time valid way through product benefit specifications. A product benefit specification has the following fields:
Table 6. Product Benefit Specification
Field Description
Product
The unique code of the product for which the product benefit specification is defined.
The unique code of the benefit specification for which the product benefit specification is defined.
Start Date
The start date of the period for which the regime will be applied. Evaluated against the claim line service date.
End Date
The end date of the period for which the regime will be applied. Evaluated against the claim line service date.
Enabled?
If unchecked, then this benefit specification will not be evaluated when determining the benefits for a claim being processed.
It is not allowed to specify multiple enabled product benefit specifications for the same benefit specification that overlap in time
A product benefit specification can have parameter values. These reflect the actual dollar amounts and percentages that are used by the calculation, which allows the coverage regime (which specifies the calculation) to be reused across many different benefits.
A product benefit specification parameter is stored as a detail of a product benefit specification. There are three types of parameters; the first applies to cover withhold categories (product benefit specification values), the second to limits (product benefit specification limits) and the third to a reinsurance percentage (product benefit specification reinsurance). A product benefit specification value has the following fields:
Product Benefit Specification Value
Table 7. Product Benefit Specification Value
Field Description
The product benefit specification to which the parameter applies.
Cover Withhold Category
Cover withhold rules of this category are parameterized by the specified amount or percentage.
Alias Code
The alias code of the parameter.
Display Name
The display name of the parameter.
Amount
The amount per unit to be used by cover withhold rules of the specified cover withhold category.
Amount Currency
The currency of the amount per unit; it is automatically set to the currency that is specified on the product.
Percentage
The percentage to be used by cover withhold rules of the specified cover withhold category.
Start Date
The start date of the period for which the parameter will be applied (evaluated against the claim line service date).
End Date
The end date of the period for which the parameter will be applied (evaluated against the claim line service date).
Constraints:
  • A product benefit specification value can only reference a product benefit specification that refers to a coverage benefit specification
  • It is not allowed to specify multiple product benefit specification values for the same product benefit specification and cover withhold category that overlap in time
  • Either the amount or percentage must be filled, but not both
  • The time validity of a product benefit specification value must be within the time validity of the product benefit specification
A product benefit specification limit has the following fields:
Product Benefit Specification Limit
A product benefit specification limit defines which limit (i.e. actual amount, number of units or number of service days) is defined within a specific product benefit specification. In this way, reuse of regimes is easy where limits only vary in amount, number of unites or number of service days, even within the same product.
Table 8. Product Benefit Specification Limit
Field Description
Limit
The limit to be used when a cover withhold rule counts towards the specified limit.
Alias Code
Display Name
Maximum Amount
The cover withhold rule category to which this limit counts.
Reached Action
Specifies what should happen when the limit is reached: stop or continue applying the rule.
Exclude From Carry Over Indicator
Is consumption for this product benefit specification limit excluded from counting towards a carry over if a carry over period is configured and the consumption falls within that period?
Start Date
The start date of the period for which the limit will be applied (evaluated against the claim line service date).
End Date
The end date of the period for which the limit will be applied (evaluated against the claim line service date).
Constraints:
  • A product benefit specification limit can only reference a product benefit specification that refers to a coverage benefit specification
  • It is not allowed to specify multiple product benefit specification limits for the same product benefit specification, limit and cover withhold category that overlap in time
  • It is not allowed to specify multiple product benefit specification limits for the same product benefit specification and limit that overlap in time without specifying the cover withhold category
  • All product benefit specification limits for the same cover withhold category must count either units, days or amounts
  • The product benefit specification limit must specify a maximum that complies with the limit type
  • Both the cover withhold category and reached action have to be set or both have to be unspecified
  • The time validity of a product benefit specification limit must be within the time validity of the product benefit specification
A product benefit specification reinsurance has the following fields:
Product Benefit Specification Reinsurance
Table 9. Product Benefit Specification Reinsurance
Field Description
Alias Code
The alias code of the reinsurance parameter.
Display Name
Start Date
End Date
Note that this parameter does not specify a value. The applicable reinsurance percentage is derived while a claim line is processed and therefore not stored as configuration.
Constraints:
  • A product benefit specification reinsurance can only reference a product benefit specification that refers to a coverage benefit specification
  • The time validity of a product benefit specification reinsurance must be within the time validity of the product benefit specification
  • It is not allowed to specify multiple product benefit specification reinsurance records for the same product benefit specification and alias code that overlap in time
  • A product benefit specification reinsurance must specify an alias code
How Limit Parameter Values are Applied
Information which limit to apply and how to apply it can be stored on different levels within the product. Consider the following table:
Table 10. How Limit Parameter Values are Applied
Level Prio Can specify / override the Maximum? Can specify / override the Reached Action? Can cause the limit to apply?
Claim Line Limit
1
Yes
Yes
Yes
Policy Product Parameter
2
Yes
No
No
3
Yes
Yes
Yes
Product Limit
4
Yes
No
No
Cover Withhold Rule (Count Towards Limit)
5
Yes
Yes
Yes
The priority indicates how the different levels interact in case more than one level specifies a height. For example, both the coverage regime and the claim line limit specify a dollar amount for an in-network deductible, the dollar amount on the claim line is applied.
The Policy Product Parameter Limit and the Product Limit can override the maximum, but whether the limit actually applies depends on other configuration.
Once the limit is selected, it is checked whether the limit is subject to prorating. This is the case when a prorating dynamic logic function is defined on the limit. The dynamic logic function is then executed and the result of this function is the height of the limit that is applied. If no dynamic logic function is defined on the limit, no prorating is done.
The applied height and reached action are not necessarily specified on the same level. Consider the following example where both a claim line limit, a product benefit specification limit and a product limit apply:
Table 11. Example
Level Height Reached Action
Claim Line Limit
1500
2000
Continue
2500
Stop
Applied
1500
Continue
Applied after prorating
750
Continue
In the event that a cover withhold rule counts towards a limit but none of the levels specify a limit and height, then the cover withhold rule behaves as though it does not count towards that limit at all.
How Cover Withhold Parameter Values are Applied
During the evaluation of a coverage regime, whenever a cover withhold rule is applied, the system looks for an applicable parameter value. This value can be specified on different levels. The level on which the parameter is set also determines the override sequence (prio) in the event that multiple values are retrieved:
Table 12. How Cover Withhold Parameter Values are Applied
Level Prio
Claim Line Parameter
1
2
3
Cover Withhold Rule
4
A claim line parameter can specify a product. If a product is specified, then it can only be used within the context of a product benefit specification that references the same product; if no product is specified, then it can be used within the context of any product benefit specification. An applicable claim line parameter thus meets two conditions; (1) it specifies the same cover withhold category as the cover withhold rule and (2) its product - if specified - must match the product of the product benefit specification.
An applicable product benefit specification parameter value specifies (1) the same cover withhold category as the cover withhold rule and (2) is attached to the product benefit specification that invoked the coverage regime. If a policy product parameter matches the alias code of the applicable product benefit specification value, it is applied instead of the product benefit specification value.
In the event that an applicable parameter value is found, the amount or percentage is applied as if it was specified on the cover withhold rule itself.
How Reinsurance Parameters are Applied
Once a claim is finalized, the application determines for each claim line whether it should generate financial transaction details that represent a receivable from the reinsurance carrier, for a percentage of the claim line covered amount. This happens only if the claim line was adjudicated based on a product benefit specification that has one or more product benefit specification reinsurance records, AND the enrollment response included a reinsurance percentage for one or more alias codes on those product benefit specification reinsurance records.
1. Limits that do not count across products are shared by products that have the same aggregation level value. Limits that do count across products ignore a product’s aggregation level and are shared by all products
