Case Definitions
Consider the following setup:
Table 1. Case Definition
Field Description
Code
CONFBARI
Description
Confined Bariatric
Start Dynamic Function
Service date - 1 week
End Dynamic Function
Service date + 1 week
Primary Claim Line Recognition Message
I-1221
Ancillary Claim Line Recognition Message
I-1222
Message for Ancillary
F-1234
Inheritable Primary Provider Group Scope
IN
Primary Claim Line Procedure Group
BARIATRIC SURGERY
Diagnosis Group Usage
Primary Claim Line
Diagnosis Group
Primary Claim Line Condition
Table 2. Ancillary Inclusion Rule
Procedure Group Diagnosis Group Usage Diagnosis Group Dynamic Condition
Nutritional counseling
and
Table 3. Case Definition
Field Description
Code
EXTEBARI
Description
Extended Bariatric
Service date - 4 months
Service date + 4 months
I-1221
I-1222
F-1234
IN
BARIATRIC SURGERY
Primary Claim Line
Diagnosis Group
Table 4. Ancillary Inclusion Rule
Weight watchers
IN
MORBID OBESITY
Fitness membership
IN
MORBID OBESITY
Liposculpture
IN
MORBID OBESITY
There are 2 products used in the use cases
  • Product ABC
    • With a benefit specification that links to 'CONFBARI'
  • Product DEF
    • With a benefit specification that links to 'EXTEBARI'
Scenario A
Person A has product ABC.
Claim 1234, comes in with on line 1, procedure '99118 Bariatric surgery' with start date '2010-07-14'. When this claim line is processed the steps in this flow produce the following results
Table 5. Scenario A
Step Result
Select case definitions
CONFBARI is selected as a possible case definition
Retrieve existing cases
No existing cases are selected.
Apply ancillary recognition rules
Is skipped
Attach as ancillary
Is skipped
Determine case end date
Is skipped
Set case end date
Is skipped
Apply primary recognition rules
Claim line is recognized as primary because procedure 99118 is included in 'Bariatric Surgery'
Determine case start date
2010-07-07
2010-07-21
End overlapping case
No existing cases, so no action
Create new case
A new case is created for
  • Person A
  • Case definition: CONFBARI
  • Start date: 2010-07-07
  • End date: 2010-07-21
  • Primary claim line: Claim 1234, line 1
Claim 1235, comes in with 3 lines
  • line 1 procedure '88312 Nutritional counseling' with start date '2010-07-05'.
  • line 2 procedure '88312 Nutritional counseling' with start date '2010-07-12'
  • line 3 procedure '81671 Fitness membership' with start date '2010-06-01', diagnosis 'MORBID OBESITY'
When line 1 is processed the steps in this flow produce the following results
Table 6. When Line 1 is Processed
Step Result
The existing CONFBARI case from 2010-07-07 to 2010-07-21 is not selected, because line 1 is outside of the date range of this case
Is skipped
Attach as ancillary
Is skipped
Is skipped
Set case end date
Is skipped
Line 1 is not recognized as a primary claim line
Determine case start date + subsequent steps
Are skipped
When line 2 is processed the steps in this flow produce the following results
Table 7. When Line 2 is Processes
Step Result
The existing CONFBARI case from 2010-07-07 to 2010-07-21 is selected, because line 2 is within the date range of this case
Line 2 is recognized as ancillary
Attach as ancillary
Line 2 of claim 1235 is attached as ancillary to the case
The case already has an end date so determine case end date is not executed
Set case end date
Is skipped
Apply primary recognition rules + subsequent steps
Are skipped
When line 3 is processed the steps in this flow produce the following results
Table 8. When Line 3 is Processed
Step Result
The existing CONFBARI case from 2010-07-07 to 2010-07-21 is not selected, because line 3 is outside of the date range of this case
Is skipped
Attach as ancillary
Is skipped
Is skipped
Set case end date
Is skipped
Line 3 is not recognized as primary
Are skipped
The final result is a case with the following data
  • Person A
  • Primary claim line: Claim 1234, line 1, procedure '99118 Bariatric surgery' , start date '2010-07-14'
  • Ancillary claim line: Claim 1235, line 2, procedure '88312 Nutritional counseling' , start date '2010-07-12'
Scenario B
Person B has product DEF.
Table 9. Scenario B
Step Result
EXTEBARI is selected as a possible case definition
Is skipped
Attach as ancillary
Is skipped
Is skipped
Set case end date
Is skipped
2010-03-14
2010-11-14
Create new case
  • Person B
  • Case definition: EXTEBARI
  • Start date: 2010-03-14
  • End date: 2010-11-14
Table 10. Results of Processing Line 1
Step Result
The existing EXTEBARI case from 2010-03-14 to 2010-11-14 is selected.
Line 1 is recognized as ancillary
Attach as ancillary
Line 1 is attached as ancillary to the existing case
The case already has an enddate.
Set case end date
Is skipped
Are skipped
Table 11. Results of Processing Line 2
Step Result
Attach as ancillary
Set case end date
Is skipped
Are skipped
Table 12. Results of Processing Line 3
Step Result
Line 3 is recognized as ancillary.
Attach as ancillary
Line 3 of claim 1235 is attached as ancillary to the case
Set case end date
Is skipped
Are skipped
  • Person B
  • Ancillary claim line: Claim 1235, line 1, procedure '88312 Nutritional counseling' , start date '2010-07-05'
  • Ancillary claim line: Claim 1235, line 3, procedure '81671 Fitness membership' , start date '2010-06-01'
Scenario C
Person C has product ABC and DEF. The same set of claims and claim lines arrives for person C as for person A and person B. Because person C has 2 products both 'Confined Bariatric' and 'Extended Bariatric' applies. The result is that Claim 1234, line 1 is the primary claim line for 2 cases and the claim lines can be ancillary to 2 cases.
The final results for person C are the following 2 cases
  • Person C
  • Primary claim line: Claim 1234, line 1, procedure '99118 Bariatric surgery', start date '2010-07-14'
  • Person C
