Case Recognition Scenario
Table 1. Case Recognition Scenario
Sequence Procedure Benefits Provider Person Comment
1
A2341
Dr Jackson (OON)
John Doe
Ancillary to case ABC
2
B6687
Dr Smith (IN)
John Doe
Not case related
3
C9348
Dr Smith (IN)
John Doe
Primary case ABC
4
D3921
Dr Jackson (OON)
John Doe
Dr Jackson is not in a product provider group. Dr Smith is.
Person John Doe is subscribed to the BASE product on all service dates in the claim.
Product Benefit Specifications
Table 2. Product Benefit Specifications
Product Code Proc Grp Contains Product Netw Case Def Regime
BASE
B1
A2341 and D3921
IN
ABC
Covered in Full
BASE
B2
A2341 and D3921
OON
ABC
Coinsurance 20
BASE
B3
A2341
IN
Copay 20
BASE
B4
B6687
IN
Covered in Full
BASE
B5
B6687
OON
Copay 20
BASE
B6
C9348
EITHER
ABC
Covered in Full
Case Definition
Recognition rules for ABC. If the primary line is IN, then out of network ancillary lines treated as IN as well.
Table 3. Case Definition
Type Proc Grp Contains
Primary
C9348
Ancillary
A2341 and D3921
Flow
Starting assumptions: there is no case for case definition ABC
Benefit Selection Phase 1
The lines are processed in sequence 1,2,3,4.
Line 1: the selection on procedures, diagnosis, person age, person gender and dynamic conditions leaves only B1, B2 and B3. Because this set contains at least one specification with a case definition (two to be exact, B1 and B2) OHI Claims continues to evaluate if line 1 qualifies as a primary line.
Before checking if line 1 qualifies as a primary line, it needs to be made sure that line 1 does not also qualify as an ancillary line to an already existing case, as this takes precedence. First, it is checked if line 1 can be attached to an existing case ABC; which it can not. Second, it is checked if line 1 is recognized as primary; again, it does not. Line 1 is marked as possible ancillary. B1, B2 and B3 are marked as possible candidates for line 1.
Line 2: the selection on procedures, diagnosis, person age, person gender and dynamic conditions leaves only B4 and B5. Neither benefit specification refers to a case definition, so line 2 continues with the evaluation of the product provider group status. The result is that B4 remains as the only candidate for line 2.
Line 3: the selection on procedures, diagnosis, person age, person gender and dynamic conditions leaves only B6. Since B6 refers to a case definition, so OHI Claims continues by evaluating if line 3 is a primary line.
Before checking if line 3 qualifies as a primary line, it needs to be made sure that line 3 does not also qualify as an ancillary line to an already existing case (since this takes precedence). First, it is checked if line 3 can be attached to an existing case ABC; which it can not. OHI Claims then checks to see if line 3 qualifies as primary; which it does. Line 3 creates a new case. B6 is marked as the only possible candidate for line 3.
Line 4: the selection on procedures, diagnosis, person age, person gender and dynamic conditions leaves only B1 and B2. Because this set contains at least one specification with a case definition (in fact both specifications) OHI Claims continues to evaluate if line 4 qualifies as a primary line.
Before checking if line 4 qualifies as a primary line, it needs to be made sure that line 4 does not also qualify as an ancillary line to an already existing case (since this takes precedence). First, it is checked if line 4 can be attached to an existing case ABC; which it can. Because this takes precedence, it’s no longer necessary to check if line 4 would start a case. Line 4 is marked as possible ancillary. B1 and B2 are marked as possible candidates for line 4.
On overview of the results after phase 1:
Table 4. Results after Phase 1
Claim Results
Sequence
Procedure
Benefits Provider
Person
Possible Ancillary?
Ben Specs
1
A2341
Dr Jackson (OON)
John Doe
Yes
B1, B2 and B3
2
B6687
Dr Smith (IN)
John Doe
No
B4
3
C9348
Dr Smith (IN)
John Doe
No
B6
4
D3921
Dr Jackson (OON)
John Doe
Yes
B1 and B2
Benefit Selection Phase 2
Phase two only processes lines that are possible ancillaries to an existing case. This means line 1 and 4.
Line 1: Line 1 starts with the selection from phase 1, that is, B1, B2 and B3. First, OHI Claims attempts to attach line 1 to an existing case. The case created by line 3 in phase 1 is found and line 1 qualifies as an ancillary line to that case.
The next step is that the remaining benefit specification is filtered in context of case definitions: because B3 does not specify a case definition, it is eliminated.
The last filter is in the context of the provider group status. Because line 1 is part of a case of definition ABC, it is treated as IN given that the primary line (line 3) is IN. Therefore, benefit specification B2 is eliminated. Only B1 remains.
Line 4: Line 4 starts with the selection from phase 1, that is, B1 and B2. First, OHI Claims attempts to attach line 4 to an existing case. The case (of definition ABC) created by line 3 in phase 1 is found and line 4 qualifies as an ancillary line to that case.
The next step is that the remaining benefit specification is filtered in context of case definitions: both B1 and B2 specify case definition ABC, neither is eliminated.
On overview of the results after phase 2:
Table 5. Results After Phase 2
Claim Results
Sequence
Procedure
Benefits Provider
Person
Ben Specs
1
A2341
Dr Jackson (OON)
John Doe
B1
2
B6687
Dr Smith (IN)
John Doe
B4
3
C9348
Dr Smith (IN)
John Doe
B6
4
D3921
Dr Jackson (OON)
John Doe
B1
After phase 2, the evaluation of the regimes can start.
