Integration Points Overview
The following tables provides an overview of the integration points that are available for exchanging data with Oracle Insurance Gateway
| Integration Point | Purpose | Inbound/Outbound | Realtime/Batch |
Access Tokens |
Returns OAuth2 access tokens |
Outbound |
Realtime |
Control Task Processing |
The "taskprocessing" resource can be used to:
Both |
Realtime |
Credentials |
Manage credentials |
Both |
Realtime |
Data File Set |
Uploading of files |
Inbound/Outbound |
Batch |
Data Set Operations / Config Migration |
Creates, updates and deletes configuration. |
Both |
Batch |
Event Store |
Provides ability to log an event |
Inbound |
Realtime |
Exchange |
Provides the ability to invoke an integration |
Inbound |
Realtime/Batch |
Key Stores |
Configure key stores |
Realtime |
Notification |
Reads inbound notifications and resumes suspended exchanges |
Inbound |
Realtime |
Provisioning Integration Point |
Provision Oracle Insurance Gateway with user and user roles |
Inbound |
Realtime |
Purge |
Provides ability to delete exchanges and events |
Inbound |
Batch |
User Information |
Provides the ability to fetch the user information (user preferences, access restriction grants, etc.) and to update the user preferences of the logged in user |
Inbound |
Realtime |
The following table lists additional usage characteristics of those integration points and places them into context:
| Integration Point | Usage Frequency | Must Have or Option |
Access Tokens |
Frequently |
Must Have when using OAuth |
Incidentally |
Option |
Credentials |
Incidentally |
Must Have when securing REST |
Data File Set |
Frequently |
Must Have |
Incidentally when configuration needs to change |
Option |
Provisioning |
Incidentally, to give new users access to the system |
Must Have |
User Information |
Frequently |
Must Have |
Exchange |
Frequently |
Must Have |
Key Store |
Incidentally |
Notification |
Frequently |
Must Have |
Event Store |
Frequently |
Must Have |
Purge |
Incidentally |
Option |
