Validate Installation
To validate successful installation of the application - and for validating accessibility of the application throughout - the application exposes a health check endpoint. This is a simple endpoint that can be accessed without authentication, which responds with a simple diagnostic message (that is, HTTP 200 'OK'). Below is an example of how this is done through cURL.
curl -v http://<<hostname>> * Trying 10.252.13.175:27052... * TCP_NODELAY set * Connected to <<hostname>> (IP) port <<port>> (#0) > GET /health HTTP/1.1 > Host: hostname:portnumber > User-Agent: curl/7.65.3 > Accept: */* > * Mark bundle as not supporting multiuse < HTTP/1.1 200 OK < Date: Wed, 11 Mar 2020 08:34:22 GMT < Transfer-Encoding: chunked < Content-Type: text/plain; charset=UTF-8 < X-ORACLE-DMS-ECID: b4dcc298-1fbe-4599-ac09-011d1f33e9cf-00002cd6 < X-ORACLE-DMS-RID: 0 < * Connection #0 to host <<hostname>> left intact OK
Another way of validating the installation is by checking if the HTTP API services endpoint can be accessed; URL format is:
http://[hostName]:[portNumber]/[api-context-root]
| The default context-roots like "/api" may have been overridden when a deployment plan was used to deploy the application. Also, the URIs for accessing application end points may only be accessible via a load balancer. |
