Operational Reporting Integration Point
Introduction
The Operational Reporting integration point processes a JSON input payload, performs necessary validations, and retrieves the relevant data for reporting. Once the validations are done then the query is run, and the results are sent as a JSON response. This IP logs any access to PHI data.
This IP accepts request to query reporting views only. Querying base views is not allowed.
Request
Operations
This IP supports the following operations:
POST   /api/operationalreporting/query
GET    /api/operationalreporting/definition
GET    /api/operationalreporting/metadata
Payload
  "columns": [
    { "expr": "a.col1" },
    { "expr": "b.col2" },
    { "expr": "sum(c.col3)" },
    { "expr": "substr(a.col2,1,1)", "alias": "initial" }
  "from": "view a",
  "joins": [
    { "type": "inner", "object": "view2 b", "condition": "a.fk1_id=b.id" },
    { "type": "left outer", "object": "view3 c", "condition": "a.fk2_id=c.id" },
    { "type": "right outer", "object": "view4 d", "condition": "a.fk3_id=d.id" },
    { "type": "full outer", "object": "view5 e", "condition": "a.fk4_id=e.id" }
  "where": "a.col2 > 'abc' and datecol > DATE '2024-02-15'",
  "groupBy": "c.col3",
  "orderBy": "a.col1 desc, b.col2 asc",
  "offset": 20,
  "fetchNext": 10
Authorization
This IP requires a grant for access restriction operationalreporting IP.
Response
If you do not have access to one or more reporting views included in the request, then HTTP 204 response is returned.
Payload
  "hasMore": false,
  "count": 25,
  "limit": 15,
  "offset": 3,
  "items": [
      "col1": "alpha",
      "col2": "beta",
      "sum(c.col3)": "125",
      "initial": "DR"
      "col1": "gamma",
      "col2": "delta",
      "sum(c.col3)": "200",
      "initial": "MS"
Error Messages
Table 1. Error Messages
Code Severity Message
OHI-IP-ORV-001
Fatal
From attribute is mandatory.
OHI-IP-ORV-002
Fatal
Type, object, and condition are mandatory for joins attribute.
OHI-IP-ORV-003
Fatal
Unsupported join type specified in joins attribute.
OHI-IP-ORV-004
Fatal
Expr is mandatory for columns attribute.
OHI-IP-ORV-005
Fatal
FetchNext should be greater than or equal to 0 and cannot be more than 200.
OHI-IP-ORV-006
Fatal
Invalid request. Potential SQL injection detected.
OHI-IP-ORV-007
Fatal
Offsets should be greater than or equal to 0.
OHI-IP-ORV-008
Fatal
View {0} does not exist.
OHI-IP-ORV-009
Fatal
Access restriction grant is missing to query the view {0}.
GEN-ORA-ERR
Fatal
DB/SQL exception.
GEN-PROC-ERR
Fatal
Technical/unknown exceptions.
