Required Software
The following table lists the Oracle software that is required in order to execute Oracle Health Insurance:
Table 1. Required Software
Oracle Product Versions
Oracle Database Enterprise Edition
19c (latest patch release)
Partitioning (Oracle Database Enterprise Edition Option)
Oracle WebLogic Suite for Oracle Applications (may be used only as an embedded runtime for eligible Oracle Applications)
Options required with WebLogic: Oracle Coherence;
14.1.0.0.0 (latest patch release)
Minimal required patches, to be applied in the order mentioned:
  • 37732915 WLS PATCH SET UPDATE 14.1.1.0.250320
  • 37658354 Coherence 14.1.1 Feature Pack 22.06 Cumulative Patch 12 (14.1.1.2206.12)
For the Oracle Database and Oracle WebLogic server make sure to always apply the latest Critical Patch Updates.
The Oracle Database and Oracle WebLogic server need to be installed. Make sure to use the "Generic Installer"
For certified operating systems for the Oracle Database and Oracle WebLogic server check Certifications on My Oracle Support for these Oracle products. Oracle Health Insurance applications are developed and tested on Oracle Linux.
Make sure to check Certifications on My Oracle Support for certification of Oracle Health Insurance applications with the following:
  • Certified Java runtime versions
  • Certified browsers
The Oracle Real Application Clusters (RAC) database option can be used with Oracle Health Insurance applications in order to achieve a high-availability setup. RAC should not be used for scalability in combination with Oracle Health Insurance applications.
