Data Model
This topic outlines the data model used to handle the Operational Reporting view and the metadata from the JET user interface point of view.
Entities
The following entities are responsible for handling Operational Reporting.
  • Reporting Views
  • View Columns
  • View Floor Plans
  • User View Search Preference
Reporting Views
This is a seeded table and stores the details of all the technical views generated for each Operation Reporting need.
Attributes: The following are the attributes for this table.
CMT: No
Field Description
Code
The code associated with the view.
Alias
A 7-character abbreviation used when adding dynamic fields in a join to prevent name conflicts.
Base Entity
Stores the main entity related to this view from the table OHI Tables. This attribute is used to pull its dynamic fields for inclusion in the view.
Access
Reference to access restrictions.
Created By
Displays the name of the user who created the entry.
Creation Date
Records the timestamp when the entry was created.
Identifying Column
Captures the column name that contains PII.
UI Reporting?
Indicates whether the view is used for display on the reporting user interface.
View Columns
This is a seeded table and stores the column metadata per Reporting View. The entries in this table are read-only and automatically retrieve single-value dynamic fields from the base entity associated with the respective view.
Field Description
View Name
Stores the View ID of the Operational Report from the table Reporting View.
Column Name
Stores the column names from the referred view or usage name with a prefix DYN_ in case of dynamic fields.
Type
Stores the data type of the field.
Properties
Stores the payload in case of datatype Array or Amount (always a list).
Created By
Creation Date
PII?
Indicates whether the column contains Personally Identifiable Information. This attribute is used for audit trail purposes.
Searchable?
Indicates if this column is searchable or not. This means whether it is allowed to configure a search on this column.
Dynamic?
Indicates if the field is a dynamic field or not.
Type (Domain)
Value Description
Amount
Amount
Date
Date
Number
Number
Array
Array
String
String
Text
Text
View Floor Plans
This table stores the user configured floor plans of the technical view.
CMT: Yes
Field Description
Code
Code for the Operational Report floor plan.
Description
Description of the Operational Report floor plan.
Function Access
Foreign key to function access.
View
Stores the View ID from the table Reporting View.
Payload
Stores the floor plan payload as defined.
System?
Indicates if this is a system generated floor plan or user defined floor plan.
Enabled?
Indicates if this floor plan is still active or inactive.
User View Search Preferences
This table stores the user search preference on quick search and advance search.
CMT: No
Field Description
Description
Description of the user search preference.
User
Reference to the user.
Floorplan
Reference to the floor plan.
Preference Payload
Stores the JSON payload to capture the user preferences.
