Generate and Modify a Case Series
This section documents the process after a periodic report is executed. It also describes the process of creating a case series for analysis and modifying it before use.
The Oracle Analytics Publisher based aggregate report generation process has two parts:
Creating the configuration.
Running the report within the Oracle Analytics Publisher with that configuration.
All case series can be saved separately (as Argus case series) for further analysis, addition, or removal of cases. You can also execute the whole process of query criteria execution and report output generation in one step. The native aggregate report generation process is broken into two parts with a provision to review and update all case series.
For more information, see:
