Configuring System Management - Common Profile Switches
This section lists the configurable sections for Common Profile Switches.
Select System Configuration and then System Management to view the Common Profile Configuration screen.
Tip:
The Common Profile folder appears in a tree-view on the left panel. The components are categorized as folders. Each folder contains all the field labels associated with that section.
If any change is made in the System Management (Common Profile Switches) screen, the Argusvr2.exe and Argusvr2a.exe should be killed from each Web Server and the IIS on Oracle Argus Web / Report Servers must be reset, in order to reflect the changes made in the application.
The following table provides the list of configurable sections associated with Common Profile Switches.
Section Sub Section Description
Advanced Conditions
The Advanced Conditions configuration screen enables you to specify the number of rows to be displayed on the Advanced Condition search screen.
Argus Dossier
Report Configuration
The Oracle Argus Dossier screen enables you to modify the customizable fields of Argus Dossier.
Argus Insight
If Oracle Argus Enterprise products are enabled, the Oracle Argus Insight URL can be provided here.
Argus J
E2B
Reporting
Device Report Responsible Officer
The Argus J Configuration screen enables you to modify the customizable fields on the Argus J form.
Argus Mart
If Argus Enterprise products are enabled, Oracle Argus Mart related settings can be configured here.
Background Services
This screen enables you to configure the Common Profile Switches that affect the behavior of Background Services.
Case Form Configuration
This screen enables you to configure Common Profile Switches that affect the behavior of the Oracle Argus application
Case Processing
Assessments
Always Show Literature Data
Auto Archiving
Case Numbering
Dictionary Browser
Enable Local Unlocking
Group Data Access
Lot Number Processing
Performance
This section enables you to configure the case processing fields and items.
Database
The database related parameters can be maintained here.
Calculation functions for Case Seriousness, Listedness and Causality calculation.
Help
Centralized Online Help URL.
Local Labeling
LAM
The Local Labeling Configuration screen enables you to modify the options available through local labeling.
Network Settings
The Network Settings screen enables you to modify the settings on the Argus Safety Load Balancer Server, Argus Safety API Load Balancer URL, and Proxy.
Reporting
BIP Reporting
E2B
eMDR
eVAERS
Expedited
Expedited - BfArM
Expedited - Canada
Expedited - CIOMS
Expedited - MedWatch
MedWatch Configuration
Periodic
Scheduling
The Reporting Configuration screen enables you to modify the options available for reporting.
Security
Cryptography
LDAP
The Security Configuration screen enables you to modify the options available for security.
Session Timeout
Session expiration time in minutes
The maximum idle time allowed for a user's session. Valid range for this value is 5-1440. Default value is 30 min. Note that long running processes like CDA are controlled through the table CMN_URL_ACCESS_GLOBAL where user can specify a timeout value local to that process. Further, the user would need to set the process as IS_LONG_RUNNING = 1. By default, the following are categorized as long running:
'/REPORTS/CIOMSII/CIOMS2_SAVING.ASP'
'/AUDITLOG/AUDITLOGLIST.ASP';
'/REPORTS/CDA/CDAGENERATE.ASP',
Single Sign-On
The Single Sign-On screen enables you to modify the options available for Single Sign-On such as enabling or disabling it, its HTTP Header, Logout URL, and using Oracle Access Server SDK for LDAP Validation.
Note that in a SSO configured environment, for the SSO to take effect, the session timeout value should be set to maximum value.
User Interface
The User Interface screen enables you to modify the options available for User Interface.
Workflow
The Workflow Items screen enables you to modify the options available for Workflow Items.
For more information, see:
