Archival PDF (for sponsor users)
Users assigned to a sponsor study role typically use this archive type for mid-study data analysis or to generate a final archive of study data. This makes the data available for auditors, sponsors, sites, and regulatory agencies.
Subject data in the output files match the data the user generating the archive can see in the user interface. For more information about how to generate a request, see Generate an archive or report.
- A folder for each site containing PDFs for each subject.
For transferred subjects, .prth files documenting a subject's transfer history are included in the folders for each source site and the destination site.
For example, if a subject transfers from Site A to Site B and then from Site B to Site C, .prth files are included in the Site A, Site B, and Site C folders.
If Share with Sites and Confirm Site Downloads are both set to Yes, users at the transferred-from sites must confirm the download. - If Include Blank Forms is set to Yes, a set of blank PDFs containing active controls for each study version is included.
- A table of contents PDF.
- A request settings PDF outlining the settings used to generate the archive.
The archive does not contain any associations between repeating forms assigned to different visits or form types, or associations between a repeating form and a standard form.Modes
Available only in Testing and Production mode. To get started, Access the Reports & Archives page.
Required permissions
- Run and download all PDF request types and Audit reports. Enable Share with Sites, and Site Confirmation
Settings
| Setting | Details |
| Name | Enter a unique name (alphanumeric characters only) that does not exceed 64 characters. |
| As of Date |
| Share with Sites |
Confirm Site Downloads |
Only available if Share with sites is set to Yes.
Included in Report |
The Select Subjects option is only available if Share with sites is set to No.
| Page Size |
| Include Blank Forms |
Blank Form Format |
Only available if Include Blank Forms is set to Yes.
| Header Text |
| Footer Text |
Advanced settings
To access the Advanced Settings, select Advanced at the bottom of the Settings sidebar.
| Advanced settings | Details |
These settings work together to determine what data to include in the request output. The default for both settings is No.
| Include uploaded files |
The setting is defaulted to Yes and cannot be changed. Some form questions allow users to upload documents, such as images. By default, these documents are included in the request output. For more information, see About the Advanced Setting—Include Uploaded Files. |
| Allow archives to be stored in Oracle sFTP |
Before enabling this setting, see About eTMF . |
| Security settings |
Dispensation details
- Kit Instructions are included when a kit is dispensed as part of advanced dispensation. These instructions are displayed to site users as Dosing Instructions during dispensation. Subject PDFs continue to include the instructions after a dispensation rollback occurs.
- Before running your final extract, update your permissions to ensure unblinded pharmacist kit types and kit descriptions for blinded studies are included in the output.
Table 4-2 Here's what's included in the Visit History section
| Action | Details |
| Kit Dispensation |
| Kit Dispensation (Calculation) |
| Kit Dispensation (Titration) |
| Replacement |
| Dose Hold |
Parent topic: Available archive types and reports
