Archival PDF (for site users)
Users assigned to a site study role typically use this archive type for mid-study data analysis or to generate a final archive of study data. This makes the data available for auditors, sponsors, sites, and regulatory agencies.
Subject data in the output files match the data the user generating the archive can see in the user interface. For more information about how to generate a request, see Generate an archive or report.
The archive output ZIP file contains the following:
  • A folder for each site containing PDFs for each subject.
  • For transferred subjects, .prth files documenting a subject's transfer history are included in the folders for each source site and the destination site.
    For example, if a subject transfers from Site A to Site B and then from Site B to Site C, .prth files are included in the Site A, Site B, and Site C folders.
  • If Include Blank Forms is set to Yes, a set of blank PDFs containing active controls for each study version is included.
  • A table of contents PDF.
  • A request settings PDF outlining the settings used to generate the archive.
Modes
Available only in Testing and Production mode. To get started, Access the Reports & Archives page.
Required permissions
Users assigned to a site study role that includes the following permissions can generate this archive.
  • Confirm download of Archival PDFs and content
  • Download Archival PDFs, and Audit Reports
  • Run Archival PDFs for your site(s)
Settings
Setting Details
Name Enter a unique name (alphanumeric characters only) that does not exceed 64 characters.
As of Date
  • Select Now (default) to include all data from the beginning of your study until the date displayed.
  • Select Select Date/Time to enter a specific date. The output includes all data up to and including the date entered.
    Note: The date selected must be after the date when the first study version was created.
Included in Report
  • Select All Subjects (default) to include data for all enrolled subjects in the request output.
  • Select Select Subjects to include data for specific enrolled subjects in the request output.
    Note: If a subject number was changed, the As of Date setting determines what value is presented in the drop-down.
  • Select Select Sites to include data from specific sites in the request output.
    Note: You see the following when sites included in the archive have no subjects.
    • When hovering over the Request Settings icon to the left of the request name on the Download Archives side panel, you see all sites included in the archive, even those without subjects.
    • The Zip file includes folders for only those sites with subjects. Also, the Table of Contents and the Request Settings PDF, included in the zip file, only include sites with subjects.
Page Size
  • Letter (default) 8-1/2" by 11"
  • A4 European letter size: 210 x 297 mm
Include Blank Forms
  • Select Yes (default) to include blank forms in the PDF output.
  • Select No if blank forms are not needed.
Blank Form Format
Only available if Include Blank Forms is set to Yes.
  • Select Casebook (default) to show all forms in every visit.
  • Select Unique Forms to show one of each blank form in every visit.
Header Text
  • Enter up to 90 characters to appear at the top of each page.
  • The study name is the default.
Footer Text
  • Enter up to 30 characters to appear at the bottom of each page.
  • **Confidential** is the default.
Advanced settings
To access the Advanced Settings, select Advanced at the bottom of the Settings sidebar.
Advanced settings Details
  • Include RTSM Data
  • Include Subject Event Data
These settings work together to determine what data to include in the request output.
The default for both settings is No.
  • If Include RTSM Data is set to Yes and Include Subject Event Data is set to No,
    • The PDF includes a section labeled Subject Randomization History, which displays the randomization number and the date and time of randomization.
    • The PDF also includes a section labeled Visit History, which displays kit and dispensation details. For additional information, see the Dispensation details section below.
  • If Include RTSM Data is set to No and Include Subject Event Data is set to Yes,
    • The PDF includes a section labeled Subject Event History, which displays each event (under the Action column) and the date and time of occurrence, as well as other subject event details (under the Details column). For a complete list of details, see About the Advanced Setting—Include Subject Event Data.
  • If both are set to Yes,
    • The PDF includes a section labeled Subject History, which displays each event (under the Action column) and the date and time of occurrence, as well as other subject event details (under the Details column). For a complete list of details, see About the Advanced Setting—Include Subject Event Data.
  • If both are set to No, nothing appears in the request output.
Include uploaded files
The setting is defaulted to Yes and cannot be changed.
Some form questions allow users to upload documents, such as images. By default, these documents are included in the request output. For more information, see About the Advanced Setting—Include Uploaded Files.
Allow archives to be stored in Oracle sFTP
  • Select Yes to send an archive to the Oracle sFTP server. Requests can then be programatically transferred to an eTMF system.
  • Select No (default) if you do not need to send an archive to the Oracle sFTP server.
Before enabling this setting, see About eTMF .
Security settings
  • Prevent Form Changes is set to Yes by default and is not configurable. When submitted, the system generates a non‑recoverable password that blocks PDF edits.
  • Prevent Form Comments Changes and Prevent Content Extracts and Copying default to No, allowing users to add comments/annotations and copy PDF content. Set them to Yes to block these actions.
Subject PDFs contain a Visit History section when the Include RTSM Data setting on the Advanced Settings page is set to Yes. Keep the following in mind when viewing this information.
  • Kit Instructions are included when a kit is dispensed as part of advanced dispensation. These instructions are displayed to site users as Dosing Instructions during dispensation. Subject PDFs continue to include the instructions after a dispensation rollback occurs.
  • Before running your final extract, update your permissions to ensure unblinded pharmacist kit types and kit descriptions for blinded studies are included in the output.
Table 4-3 Here's what's included in the Visit History section
Action Details
Kit Dispensation
  • Date
  • Kit Number
  • Kit Description
  • Kit Status (Not Dispensed to Subject appears only when a dispensation rollback occurs).
  • Kit Instructions
  • Dispensation Rollback (Appears only when a dispensation rollback occurs).
  • Reason (Indicates the reason for the rollback).
  • User
Kit Dispensation (Calculation)
  • Date
  • Kit Number
  • Kit Description
  • Kit Status
  • Calculation
  • User
Kit Dispensation (Titration)
  • Date
  • Kit Number
  • Kit Description
  • Kit Status
  • Titration
  • User
Replacement
  • Date
  • Kit Number
  • Kit Description
  • Kit Status
  • Replacement Kit
  • User
Dose Hold
  • Date
  • Kit Description
  • User
