Compare records in data listings
You can select up to 100 records within the Listings grid to compare in a focused, vertical view. This may be helpful if you want to review and analyze multiple records without scrolling horizontally across the entire Listings grid.
  1. Do one of the following:
  2. After you select a study, click Data Management. Data Management in the navigation bar.
  3. Select Listings from the drop-down menu.
  4. Select the Listings type in the left panel of the screen to load the listings in the center grid.
    For details on selecting and viewing listings type, see Choose a listing type
  5. Use Ctrl+click or Shift+click to select multiple rows in the Listings grid.
  6. Right-click the selection and choose Compare Records from the context menu.
    You are taken to an isolated, vertical view of the selected records. From here, you can view more information about your selection in the panel on the right, assign flags, create a discrepancy, or navigate to any associated discrepancies.
To return to the previous view of the Listings interface, click Exit Comparison.
