View a single record from data listings
You can access a view of a single record that displays all of the columns on the Listings grid in a vertical manner. This can help you focus on one record at a time while being able to vertically scroll through the information.
  1. Do one of the following:
  2. After you select a study, click Data Management Data Management in the navigation bar.
  3. Select Listings from the drop-down menu.
  4. Select the Listings type in the left panel of the screen to load the listings in the center grid.
    For details on selecting and viewing listings type, see Choose a listing type
  5. Right-click on the record you wish to view independent of the full Listings results.
  6. Select View Record from the context menu.
    You are taken to an isolated, vertical view of the record. From here, you can view more information about your selection in the panel on the right, assign flags, create a discrepancy, or navigate to any associated discrepancies.
To return to the previous view of the Listings grid, click Exit View.
