5 Review and act on discrepancies
The section contains the following topics:
- Customize the discrepancy view
You can hide, pin, reorder columns, and save custom column widths on the discrepancies interface by using Table Settings function. - How do I create a discrepancy?
- Find discrepancies
- Act on a discrepancy
Once you find the discrepancies you need to locate, you can act on them to change the state, send to InForm or another system, modify the description, or export the details. - See more information about a discrepancy
- FAQs
