Find discrepancies
You can find particular discrepancies using one or both of the following methods:
- Filters in the left panel (use one or more fields, build an advanced filter with a formula, or both)
- Search fields at the top of the table
See the following sections for details:
- Use filters to find discrepancies
- Use the search fields to find discrepancies
You can use the Search in Column field in conjunction with the adjacent Enter Value field to search for discrepancies that match your search criteria. - Show blinded data
Parent topic: Review and act on discrepancies
