Show blinded data
As described in Use filters to find discrepancies, you can select Discrepancies from the Data Management. Data Management menu to drill down into the data and locate specific items. If your account includes the appropriate privileges and you need to show or hide blinded data, do one of the following:
  • To show blinded data, select Show Blinded Data from the Filter panel on the left and click Yes when prompted. (The system tracks the number of times you view blinded data.)
  • To hide blinded data, clear the Show Blinded Data field and click Yes when prompted.
If you selected a listing instead of discrepancies and clicked Yes when prompted to access blinded data (if available), the Show Blinded Data field appears selected already in the Filters panel (tab).
