Use the search fields to find discrepancies
You can use the Search in Column field in conjunction with the adjacent Enter Value field to search for discrepancies that match your search criteria.
Using Search in Column in conjunction with filters
- If there are filters in effect when you search in these fields, the system applies the filters and searches on these values within the filter results.
- If there are no filters in effect, the system searches across all
discrepancies.
Tip:
To see which filters are in effect, click the down arrow in the Filter: ON indicator.
Parent topic: Find discrepancies
