View the full record containing a discrepancy
  1. After you select a study, click Data Management. Data Management in the navigation bar.
    For details on selecting a study, see Select a study from the Home page.
  2. Select Discrepancies from the drop-down menu.
  3. Find the discrepancies you need to locate using the filters on the left panel or the top of the page. (See Find discrepancies for details on using the filters.)
  4. Select one discrepancy.
  5. From the View. View drop-down in the top section of the right panel, select Full Record to open the Full Record dialog box.
  6. To see a particular column, enter part of the column name in the Search field and click Search. to locate it.
  7. (Optional) Select Show Only Changes to see only items with different current and original data values.
  8. Click Close.to close the Full Record dialog box.
