View related subject listings
You can quickly navigate to the listing where the discrepancy was created from the Discrepancies interface.
  1. After you select a study, click Data Management.Data Management in the navigation bar.
  2. Select Discrepancies from the drop-down menu.
  3. Find the discrepancies you need to locate using the filters on the left panel or the top of the page. (See Find discrepancies for details on using the filters.)
  4. From the View. View drop-down in the top section of the right panel, select View All Subject Listings.
    You can also access the View All Subject Listings option from the context menu displayed after right-clicking a discrepancy in the results grid.
    You are taken to the Listings interface where the corresponding Subject filter has already been applied to Listings results.
