Use keyboard shortcuts on discrepancies
After you open the Discrepancies page, and select one or more discrepancies, you can save time and avoid using a mouse by using keyboard shortcuts to perform actions or use search fields. (The number of actions you can take on a discrepancy vary depending on the state of the discrepancy.)
Table 5-1 Keyboard Shortcuts for Discrepancies
Keyboard Shortcut Description
Ctrl+Alt+S Search for a column value: Use the keyboard shortcut and press Enter to open the Search field drop-down list and select the column you want to search. For more details, see Use the search fields to find discrepancies.
Ctrl+Alt+E Edit a discrepancy: Opens the Edit Discrepancy dialog box in the right panel. For more details, see Edit a Discrepancy.
You can only edit one discrepancy at a time. To open the Edit Discrepancy dialog box for more than one discrepancy at a time, select multiple discrepancies and click Edit for each discrepancy you opened. Do not use the keyboard shortcut.
Ctrl+Alt+Q Ready to Send to InForm (if available): Opens the Ready to Send to InForm dialog box in the right panel.
Ready to Send to Clinical One (if available): Opens the Ready to Send to Clinical One dialog box in the right panel.
For more details, see Change the state of multiple discrepancies.
Ctrl+Alt+C Close one or more discrepancies: Opens the Close Discrepancy dialog box in the right panel (for one or more discrepancies). For more details, see Change the state of multiple discrepancies.
