Configuring the InForm Publisher application using PublisherAdmin
The PublisherAdmin command allows you to configure the InForm Publisher application from the command line. The PublisherAdmin command line syntax contains the following commands, each with its own set of parameters:
The command line executable file, PublisherAdmin.exe, is available in the \Bin folder of the location where you installed the InForm Publisher software.
