3 Custom Configuration
Brand owners may customize aspects of the portal. Custom fields can be used to extend records for the capture of additional data; images and styles can be overridden to apply custom branding and theming. The contents of the notification emails can also be customized.
Custom Fields
The layout of the custom fields depends on the different types of fields specified when the record is defined. The actual configuration of the custom fields is a portal implementation task, currently only accessible by the Oracle Authorized User administrator. For product specifications, custom fields can be configured per section and/or as a specific section of the specification.
Figure 3-2 shows an example of a page layout with different field types.
The Custom Fields subtab appears to the left of the Change History subtab. If a record is copied, the custom fields are copied to the new record.
If custom fields are available for a record, the Custom Fields subtab is available on the record page. Figure 3-1 shows an example of the location of the tab.
There is a limitation in the configurable mandatory field rules for Product Specifications with relation to custom fields. While it is possible to apply mandatory validation to custom fields in each section of the specification, it is not possible to do so in the main Custom Fields section of the specification.
Also, it is not possible to configure mandatory field rules for the EAN Barcode and Shipping Case Code fields within the specification.
Figure 3-1 Custom Fields Tab
This figure shows the Custom Fields tab.
To see the custom fields data, select the Custom Fields subtab. The Custom Fields page opens.
Figure 3-2 Custom Fields Page
This figures shows the Custom Fields page.
To enter data into the fields, select the Edit action. The input fields open. Make any updates and select the Save action.
Figure 3-3 Custom Fields Open for Editing
This figure shows the Custom Fields open for editing.
Branding & Theming
The Oracle Retail Brand Compliance Management Cloud Service images and style sheets can be overridden to use custom styles, such as alternative logos or color schemes. Also, the terms and conditions can be customized. Select the System Control option and then Branding.
Managing Styles
Custom styles are applied by uploading CSS stylesheets in the Theming & Branding record. In read mode, the existing CSS files can be downloaded by clicking the hyperlinks. In edit mode, the option to upload alternative stylesheets is available. Administrators with the Oracle Authorized Administrator authority profile can edit the Theme page.
To apply a custom style:
  1. Select Branding in the left pane. The Theme page appears.
    Figure 3-4 Theming & Branding Theme Page
    This figure shows the Theming & Branding theme page.
  2. Edit the record.
  3. Click the Upload button to load a CSS file into the Custom Theme field.
  4. Select the Save action. The changes should become visible to users the next time they log in.
To customize the portal's theme, the following files need to be uploaded:
  • The Login page splash icon (800 x 400 pixels; name: loginBackground.png)
  • The portal logo displayed on the top right of the application toolbar (200 x 37-40 pixels; name: portalLogo.png)
  • The supplier registration logo (200 x 40 pixels; name: supplierRegistration.png)
The default versions can be found in the Attachments page. When changing the theme, all of the files in the Attachments page should be deleted apart from these. A quick way to do this is to select all attachments and deselect these three.
If necessary, the portal's theme can be reset to the default by Oracle Development as a support activity.
Managing Images
Custom logos and other images are applied by uploading the files in the Theming & Branding record. The Attachments page contains the resource files that are referenced by the CSS stylesheets. Administrators with the Oracle Authorized Administrator authority profile can edit the Attachments page.
To apply a custom image:
  1. Select Theming & Branding in the left pane.
  2. Edit the record and open the Attachments page.
    Figure 3-5 Theming & Branding Attachments Page
    This figure shows the Theming & Branding Attachments page.
  3. Click the New Attachment action to load a file and enter a description.
    Multiple resource files can be uploaded through a single action by uploading a ZIP file that contains the individual files. The upload will automatically unpack the individual files; the same description will be applied to each of them.
    If any of the file names are already attached, the entire upload will be prevented with the error: "The selected attachments cannot be uploaded because the file names are not unique." In this case, delete the original files before re-uploading (and amending the stylesheet if necessary).
    If changing an image such as the portal logo, upload the new image and ensure the file is referenced accordingly in the custom CSS stylesheet file.
    Image dimensions for logos should be 200x40 pixels (ideally max 200Kb).
    Image dimensions for login page backgrounds should be 400x800 pixels (ideally max 300Kb).
    To display correctly, image file types must be JPEG, GIF, or PNG format.
    The core Brand Compliance themes are available for download from the Glossaries Import/Export area, in the form of a ZIP file containing collections of the image and stylesheet files.
  4. Select the Save action. The changes should then become visible to users, if any necessary changes have been made to the CSS stylesheets.
Managing User Ts & Cs
The terms and conditions text that is presented to the user when they first log in to the system can be customized through the Theming & Branding record. Administrators with the Configuration Editor authority profile can edit the User Ts & Cs page.
To edit the User Ts & Cs text:
  2. Edit the record and open the User Ts & Cs page.
    Figure 3-6 Theming & Branding User Ts & Cs Page
    This figure shows the Theming & Branding User Ts & Cs page.
  3. Edit the text in the User Ts & Cs field. The text editor options can be used to apply text formatting such as bold and underline, and to insert hyperlinks or images. Enter any translations.
  4. Select the Save action. The changes will then become visible to new users when they log in for the first time.
Managing Supplier Ts & Cs
The terms and conditions text that is presented to the Supplier when they complete the Registration wizard can be customized through the Theming & Branding record. Administrators with the Configuration Editor authority profile can edit the Supplier Ts & Cs page.
To edit the Supplier Ts & Cs text:
  2. Edit the record and open the Supplier Ts & Cs page.
    Figure 3-7 Theming & Branding Supplier Ts & Cs Page
    This shows the Theming & Branding Supplier Ts & Cs page.
  3. Edit the text in the Supplier Ts & Cs field. The text editor options can be used to apply text formatting such as bold and underline, and to insert hyperlinks or images. Enter any translations.
  4. Select the Save action. The changes will then become visible to new Suppliers when they complete the Registration wizard.
Email Templates
The emails that are generated automatically by the system, based on certain predefined events each have a configurable template. The templates are provided as part of the portal installation.
The maintenance of the templates, in the Notifications / Email Templates page of the Admin area, is limited to just allowing the administrator to customize the content of the email; templates cannot be added or deleted.
The emails are capable of containing dynamic content through the use of predefined parameters, such as to substitute the name of the user, supplier, product, and so forth.
Table 3-1 describes the parameters are used in email templates.
Table 3-1 Email Parameters
Parameter Description
General
$createdByEmail
Email address of the user who triggered the email.
$createdByName
Name of user who triggered the email.
$emailComments
Comments in the email body.
$link
Hyperlink to a Brand Compliance record.
$loginID
$userName
Login user name of the user.
$loginUrl
$portalURL
Portal URL.
$name
Name of the user.
$portalName
$portal
Name of the portal.
$recipients
List of email recipients.
$recipientUserName
Login user name of email recipient.
$retailerName
Name of the retailer or portal owner.
$showInternationalNames
Whether international names are used.
$supportEmail
Email address of support team.
Suppliers & Sites
$site
$sites
List of sites.
$site.code
Site code.
$site.name
$siteName
$site_names
Site names, in the business language.
$site.localName
$sitelocalname
Site names, in the local language.
$supplier_local_name
$supplierlocalname
Name of the supplier, in the local language.
$supplier_name
$supplierName
Name of the supplier, in the business language.
$supplierCode
Supplier code.
Batch Jobs
$batchJobStatus
Status of batch job.
$errorMessages
Batch job error message.
$jobNumber
Batch job number.
$jobType
Type of batch job.
Projects
$activity_name
Name of activity.
$activity_status
Status of activity.
$date_and_time
Date and time of activity notification.
$end_date
Activity end date.
$errorText
Brief extract error message.
$project_name
Name of project.
$responsible
User responsible for activity.
$start_date
Activity start date.
$URL_to_activity
Hyperlink to an activity record.
Product Records
$message
Rejected surveillance test reports.
$productCode
The product's code.
$productCovered
$productsCovered
List of products covered.
$productCovered.retailerProductNumber
Product coverage product number.
$productCovered.variantName
Product coverage variant name.
$productTitle
Name of product.
$retailerProductNumber
$retailerProductNo
Alternative product number.
$packCopyVersion
Pack Copy file version number.
$specCreateStatement
Instruction to create and complete a product specification.
$specName
Name of product specification.
$specNumber
The specification's number.
$specStatus
Status of specification.
$specTitle
Title of specification.
$specVersion
Specification version number.
Alerts
$alertDescription
Description of alert.
$alertExtractError
Alert extract error message.
$alertIssueDate
Date alert was issued.
$alertProcessReport
Alert responses extract.
$alertTitle
Title of alert.
Audits & Visits
$auditLink
Hyperlink to audit/visit record.
$auditOrVisit
Audit or visit.
Scorecards
$duedate
Scorecard due date.
$fromPeriod
Range from period.
$fromYear
Range from year.
$scorecardtype
Type of scorecard.
$scorecardUrl
Hyperlink to scorecard record.
$toPeriod
Range to period.
$toYear
Range to year.
Reports
$createdOn
Date report created.
$purgeDays
Number of days before report is purged.
$reportCanceller
Name of user who cancelled report.
$reportLink
Hyperlink to report output record.
$reportName
Name of report.
$result
KPI result value.
Data Extracts
$attachmentLink
$attachmentLinks
Hyperlinks to report output attachments.
$criteriaName
Data extract criteria.
$extractErrors
Data extract error message.
$extractLink
Hyperlink to data extract report output record.
$listViewName
Data extract list view.
Usage of a parameter is subject to it being specifically coded to be available to the template.
Table 3-2 shows the parameters that can be used within each email template.
Table 3-2 Email Parameters for Email Templates
Email Code Description Parameters
Alerts
ALERT1
Notify suppliers and sites of a new alert.
$alertTitle
$alertDescription
$link
$recipientUserName
$suppliername
$supplierlocalname
$siteName
$sitelocalname
ALERT2
Notify internal users of a new alert.
$alertTitle
$emailComments
$alertDescription
$link
ALERT3
Remind suppliers to respond to an alert.
$alertTitle
$alertIssueDate
$alertDescription
$link
$recipientUserName
$suppliername
$supplierlocalname
$siteName
$sitelocalname
ALERT4
Notify suppliers that an alert has been cancelled.
$alertTitle
ALERT5
Notify suppliers that an alert response can be resubmitted.
$alertTitle
$alertDescription
$link
$recipientUserName
$suppliername
$supplierlocalname
$siteName
$sitelocalname
ALERT6
Notify a user that an extract of alert responses has completed.
$alertTitle
$link
ALERT7
Notify a user that an extract of alert responses has errors.
$alertTitle
$alertExtractError
$link
ALERT8
Notify the Alert Administrator that alert responses have been generated, listing any errors.
$alertTitle
$alertProcessReport
$link
ALERT9
Notify the Alert Administrator that a supplier would like to change their responses.
$alertTitle
$link
$suppliername
$supplierlocalname
$siteName
$sitelocalname
ALERT10
Notify suppliers that an alert response cannot be resubmitted.
$alertTitle
$alertDescription
$link
$recipientUserName
$suppliername
$supplierlocalname
$siteName
$sitelocalname
Audits & Visits
AUDIT AWAITING AMENDMENT
Generated when an audit or visit has actions rejected.
$auditOrVisit
$portal
$auditLink
AUDIT AWAITING CORRECTIVE ACTION
Generated when an audit or visit has actions to be addressed.
$auditOrVisit
$portal
$auditLink
Batch Jobs
BATCHJOBCOMPLETE
Notify user that a job has completed.
$jobType
$jobNumber
BATCHJOBSUBMIT
Notify user that a job has been initiated.
$jobType
$jobNumber
General
EXTRACT1
Notify user that a data extract job has failed.
$jobType
$extractLink
EXTRACT2
Notify user that a data extract job has successfully completed.
$jobType
$extractLink
EXTRACT3
Notify user that a data extract job has failed for an unknown reason.
$jobType
$extractErrors
HARDGOODS 01 SUPPLIER
Generated when changes are made to the Post Launch Information product specification section.
$specTitle
$portalName
$supportEmail
IDCS1
Registration request raised for a new supplier/site.
$createdByEmail
$createdByName
$portalName
$portalURL
$supportEmail
$userName
IDCS2
New user created.
$createdByEmail
$createdByName
$portalName
$portalURL
$retailerName
$supportEmail
$userName
PREVALIDATIONFAILURE
Notify the job submitter that an uploaded file has been checked and there are problems with it.
$jobType
$jobNumber
Product Record
PPROD-EMAIL1
Notification when supplier has moved a Produce product record from Draft to Active status.
$specTitle
$portalName
$supportEmail
PPROD-EMAIL2
Notification when supplier has updated the Additional Supplier Information tab.
$specTitle
$portalName
$supportEmail
PR1
Notify supplier/retailer that a new product record has been created.
$productCode
$productTitle
$supplierName
$supplierCode
$supplierlocalname
$site
$sites
$site.name
$site.localName
$site.code
ADVISEPACKCOPY
Advise ready for pack copy submission email.
$specName
$portalName
$supplierName
$supplierCode
$supplierlocalname
$site
$sites
$site.name
$site.localName
$site.code
$productCovered
$productsCovered
$specVersion
COMBINE SPEC
Notify the job submitter of the success or failure of a combine specifications action.
$jobType
$jobNumber
$batchJobStatus
$specNumber
$specVersion
$specName
$errorMessages
HARDGOODS 01 RETAILER
Changes have been made to the Post Launch Information product specification section.
$specTitle
$portalName
$supportEmail
PRI01
Notification of a new Produce specification.
$specName
$specNumber
$specVersion
$supportEmail
PRI02
Notification that Produce specification accepted.
$supplierName
$specName
$specNumber
$specVersion
$portalName
$supportEmail
SPEC4
Notification of pack copy generation.
$specName
$productTitle
$retailerProductNo
$specName
$specNumber
$specVersion
$packCopyVersion
SPECEXTRACT
Notify the job submitter that the extract of combined specification data has been processed.
$jobType
SPECEXTRACTFAILED
Notify the job submitter that the extract of combined specification data has failed.
$jobType
$errorText
SPECSTATUSRET
Notify retailer that a specification has changed status.
$specName
$specStatus
$supplierName
$supplierCode
$supplierlocalname
$site
$sites
$site.name
$site.localName
$site.code
$productCovered
$productsCovered
$specVersion
SPECSTATUSSUPP
Notify supplier that a specification has changed status.
$specName
$specStatus
$supplierName
$supplierCode
$supplierlocalname
$site
$sites
$site.name
$site.localName
$site.code
$productCovered
$productsCovered
$specVersion
TEMPSPEC-EMAIL1
Notification when supplier has moved a Temporary specification from Draft to Awaiting Approval status.
$specTitle
$portalName
$supportEmail
TEMPSPEC-EMAIL2
Notification to supplier when retailer has moved a Temporary specification from Awaiting Approval to Awaiting Corrective Action status.
$specTitle
$portalName
$supportEmail
TEMPSPEC-EMAIL3
Notification to supplier when retailer has moved a Temporary specification from Awaiting Approval to Active status.
$specTitle
$portalName
$supportEmail
Projects
PROJECT1
Notification of an activity status change.
$activity_name
$project_name
$activity_status
$date_and_time
$URL_to_activity
$project_name
$start_date
$end_date
PROJECT2
Activity notification.
$activity_name
$URL_to_activity
$project_name
$start_date
$end_date
$activity_status
$responsible
PROJECT3
Notify user that a project/activity brief job has failed.
$jobType
$errorText
$listViewName
$criteriaName
PROJECT4
Notify user that a project/activity brief extract job has successfully completed.
$jobType
$listViewName
$criteriaName
Reports
KPIDELIVERY
Notify the recipients that a KPI has been generated.
$reportName
REPORT_CANCELLED
Notify user that a report schedule has been cancelled.
$reportName
$reportCanceller
REPORTDELIVERY
Notify the recipients that a report has been generated.
$reportName
$reportLink
REPORTNOTIFICATION
Notify the external system that a report has been generated providing an API URL to retrieve the attachments.
$reportName
$attachmentLink
$attachmentLinks
REPORTPURGE
Notify user that a report is due to be purged.
$reportName
$createdOn
$purgeDays
Scorecards
SCORE1
Overdue scorecard reminder.
$site
$scorecardtype
$duedate
$suppliername
$suppliercode
$supplierlocalname
$site
$sites
$site.name
$site.code
$site.localName
$scorecardUrl
SCORE2
Scorecard extract notification.
$scorecardtype
$fromPeriod
$fromYear
$toPeriod
$toYear
$userName
Suppliers & Sites
REG2
Registration completed by supplier.
$portalName
$suppliername
$suppliercode
$supplierlocalname
$sitename
$sitecode
$sitelocalname
$link
$supportEmail
REG4
Registration request raised by retailer for additional sites.
$portalName
$site
$sites
$site.name
$site.code
$site.localName
$supportEmail
SUPPLIER ACTIVATED
Supplier activated notification.
$retailerName
$suppliername
$suppliercode
$supplierlocalname
$site
$sites
$site.name
$site.code
$site.localName
$supportEmail
Surveillance
SUR1
Supplier action required notification.
$retailerName
$portalName
$supportEmail
SUR2
Supplier action rejected notification.
$productTitle
$portalName
$supportEmail
SUR3
Test report acceptance batch job failure notification.
$message
$portalName
$supportEmail
Some email templates contain conditional and looping logic to form lists of values. For example:
  • List of a specification's supplier and sites, showing either international names or local names, depending on the setting of the system parameter:
    #if ( $showInternationalNames )
    Supplier: $supplierName $supplierCode
    $supplierlocalname
    #else
    #end
    Site: #foreach( $site in $sites )$site.name
    $site.localName
    #end
    ($site.code)
    #end
  • List of the product coverage table:
    #foreach( $productCovered in $productsCovered )$productCovered.variantName
     #if( $productCovered.retailerProductNumber
     )($productCovered.retailerProductNumber)#end
    #end
  • List of a report output's attachments:
    #foreach( $attachmentLink in $attachmentLinks )$attachmentLink
    #end
  • List of email recipients:
    #foreach( $recipient in $recipients ) $recipient.personName
     ($recipient.email)#end
