4 Job Management
Batch jobs are initiated by users when required to perform updates to records.
To manage batch jobs, select Batch Jobs from the Admin list. The Manage Batch Jobs page shows the list of all jobs. The jobs are shown in descending order with the most recent job at the top of the list.
Figure 4-1 Manage Batch Jobs Page
This figure shows Manage Batch Jobs page.
The following columns are shown for each job:
  • Job Number
  • Submitted On: Date and time when the job was submitted.
  • Submitted By: Name of the user who submitted the job.
  • Job Type
  • Description: Any comments entered when the job was submitted. If no comments were entered, the filename of any uploaded files will appear here.
  • Data: If a job was submitted using a spreadsheet, an icon is shown in this column. The user can click the spreadsheet icon and select whether to open or download the spreadsheet.
  • Status: The following icons show the job status:
    Table 4-1 Manage Batch Jobs Icons
    Icon Status Description
    This graphic shows the Created icon.
    Created
    The job is created.
    This graphic shows the Submitted icon.
    Submitted
    The job is ready to run.
    This graphic shows the In Progress icon,
    In Progress
    The job is currently running.
    This graphic shows the Completed icon.
    Completed
    The job completed. All changes were successfully made.
    This graphic shows the Failed icon.
    Failed
    Errors were encountered. Changes were not made.
    This graphic shows the Cancelled icon,
    Cancelled
    The job was cancelled.
    This graphic shows the Internal Failure icon.
    Internal Failure
    An internal failure occurred.
You can choose which batch jobs you want to view. The following list views are available:
  • All Jobs
  • Failed Jobs: Show jobs with a status of failed.
  • Running Jobs: Shows jobs with a status of in progress.
  • Site TM Changes: Shows jobs with a job type of Change Site Technologist.
A housekeeping job automatically removes entries with a status of Completed from the Batch Job log 90 days after their submission date.
Opening a Batch Job
To open a batch job, double click the job in the list. The job will open as a new tab.
  • The job's bookmark shows the Job Number and the Job Type.
  • A Messages tab appears if any errors were encountered when the job ran.
  • An Attachments tab stores the file used to upload data, or where applicable, a rejects file containing records that could not be uploaded due to errors.
  • A Linked Jobs tab shows links to related jobs if part of a series of jobs.
System Parameters
To maintain the parameters used to support Job Management, select the System Control option and then System Parameters.
Table 4-2 shows the specific system parameters, by subtab on the System Parameters page, used to support Job Management.
Table 4-2 System Parameters
Subtab Parameter Description
Global
System Time Zone
UTC time zone offset parameter for batch jobs. In this release, this parameter only impacts new batch jobs.
Existing batch jobs will remain based on UTC as they currently are unless associated documentation states otherwise.
Range is -12:00 to +12:00 with a default of +00:00.
