3 Dynamic Configuration
This chapter describes the concept and the configuration of running EFTLink Dynamic Cores.
Dynamic configuration is controlled via the EFTLinkConfig.properties setting DynamicConfiguration (true by default) and can either be set to true or false.
This allows a POS to override the configuration of EFTLink and any active core that would normally receive their instruction from their respective properties files. This is achieved by the POS sending through an Administrative Service request. There are five sub types of Administrative Service request, these are detailed in the table below:
Table 3-1 Administration Request Sub Types
| Setting | Description | Notes |
| Capability | For any initialized core, a capability request can be sent to check whether that core supports the transaction types. | Supported Transaction type that can be checked are Manual PAN, Loyalty, Reversal, and Cancellation requests. |
| GetConfig | For any initialized core, this request can be sent to retrieve the current configuration settings for an active core. | Can be useful in conjunction with Uninitialise request. For example, Initialise are core, gather configuration, Uninitialise and then Initialise core again with new setting sent within the Initialise request. |
| Initialise | This request must declare the EPSCore(s) that are to be initialized. If no EPSCore is declared, then EFTLink will revert
to the  If no properties are declared within the service request that declares which EPSCores(s) are initialized then EFTLink will revert to defaults. | An Initialise request must be sent before a logon request. If an Initialise request is sent specifying an EPSCore, then EftlinkConfig.properties is not used and all properties that deviate from defaults setting must come from within the request. Any properties specified inside an EPSCore element is targeted to that core only whereas any properties specified outside are used for all specified cores declared in the service request. Core properties are read in from their respective property files. However, any properties specified within this request will take precedence. |
| Shutdown | Instructs EFTLink to shut down. | Please note that this terminates EFTLink and therefore EFTLink will not be able to acknowledge nor respond back to the request. |
| Uninitialise | Closes all Initialise cores. | If a core is initialized, then the core configuration is static. If core needs reconfiguring, then this is possible by sending an Uninitialise request followed by an Initialise request which declares the new configuration changes. |
Figure 3-1 EFTLink and Core Initialized through the reading in of Property Files followed by Capability Request
Figure 3-2 EFTLink and Core initialized via POS initialise Server Request
Example Administrative Service Requests and Responses
Capability
Capability Request
<?xml version="1.0" encoding="UTF-8"?>
<ServiceRequest RequestID="2" WorkstationID="Workstation: 10100" ApplicationSender="EFTLink Load Tester" RequestType="Administration" RequestSubType="Capability">
  <PrivateData>
    <Property Key="Cancellation"/>
    <Property Key="Reversal"/>
    <Property Key="ManualPAN"/>
    <Property Key="Loyalty"/>
  </PrivateData>
  <POSdata LanguageCode="en">
    <POSTimeStamp>2021-08-19T14:03:52</POSTimeStamp>
  </POSdata>
</ServiceRequest>Capability Response (single active core)
<ServiceResponse RequestID="2" WorkstationID="Workstation: 10100" OverallResult="Success" ApplicationSender="EFTLink Load Tester" RequestType="Administration" RequestSubType="Capability">
  <PrivateData>
      <Property Value="false" Key="Loyalty"/>
      <Property Value="true" Key="Reversal"/>
      <Property Value="false" Key="ManualPAN"/>
      <Property Value="true" Key="Cancellation"/>
  </PrivateData>
</ServiceResponse>Capability Response (multiple active core)
  <PrivateData>
    <Core0 CoreName="oracle.eftlink.opiretail.OPIRetailCore">
    </Core0>
    <Core1 CoreName="oracle.eftlink.opiretail.OPIRetailCore">
    </Core1>
  </PrivateData>
</ServiceResponse>GetConfig
GetConfig Request
<ServiceRequest RequestID="3" WorkstationID="Workstation: 10100" ApplicationSender="EFTLink Load Tester" RequestType="Administration" RequestSubType="GetConfig">
    <POSTimeStamp>2021-08-19T14:03:53</POSTimeStamp>
  </POSdata>
</ServiceRequest>GetConfig Response (single active core)
<ServiceResponce RequestID="3" WorkstationID="Workstation: 10100" ApplicationSender="EFTLink Load Tester" RequestType="Administration" RequestSubType="GetConfig">
  <PrivateData>
      <Property Value="false" Key="QuickChipEnabled"/>
  </PrivateData>
</ServiceResponse>GetConfig Response (multiple active cores)
<ServiceResponse RequestID="3" WorkstationID="Workstation: 10100" ApplicationSender="EFTLink Load Tester" RequestType="Administration" RequestSubType="GetConfig">
  <PrivateData>
    </Core0>
    </Core1>
 </PrivateData>
</ServiceResponse>Initialise
Initialise Request
<ServiceRequest RequestID="1" WorkstationID="Workstation: 10100" ApplicationSender="EFTLink Load Tester" RequestType="Administration" RequestSubType="Initialise">
  <PrivateData>
    <Property Value="20" Key="InvalidCorePromptTimeout"/>
    <Property Value="true" Key="DynamicConfiguration"/>
    <EPSCore Id="0" Name="oracle.eftlink.opiretail.OPIRetailCore">
      <Property Value="false" Key="LineDisplayEnabled"/>
      <Property Value="true" Key="CardAcquisitionEnabled"/>
    </EPSCore>
  </PrivateData>
    <POSTimeStamp>2021-08-20T13:17:02</POSTimeStamp>
  </POSdata>
</ServiceRequest>Initialise Response
<ServiceResponse RequestID="1" WorkstationID="Workstation: 10100" ApplicationSender="EFTLink Load Tester" RequestType="Administration" RequestSubType="Initialise">
  <PrivateData>
    </EPSCore>
  </PrivateData>
  </POSdata>
</ServiceResponse>Shutdown
Shutdown Request
<ServiceRequest RequestID="5" WorkstationID="Workstation: 10100" ApplicationSender="EFTLink Load Tester" RequestType="Administration" RequestSubType="Shutdown">
    <POSTimeStamp>2021-08-20T13:18:01</POSTimeStamp>
  </POSdata>
</ServiceRequest>Shutdown Response
EFTLink doesn't send a response to a shutdown request because it is shutdown.
Uninitialise
Uninitialise Request
<ServiceRequest RequestID="4" WorkstationID="Workstation: 10100" ApplicationSender="EFTLink Load Tester" RequestType="Administration" RequestSubType="Uninitialise">
    <POSTimeStamp>2021-08-20T13:17:23</POSTimeStamp>
  </POSdata>
</ServiceRequest>Uninitialise Response
<ServiceResponse RequestID="4" WorkstationID="Workstation: 10100" OverallResult="Success" ApplicationSender="EFTLink Load Tester" RequestType="Administration" RequestSubType="Uninitialise"/>
