18 Seeding Application Dashboards
Retail Home provides two methods to seed configurations for applications. The first, discussed in Application Navigator Setup, is to press the seed data button on the application navigator configuration screen. Additionally, data may be loaded in bulk by making direct calls to the seed service.
Calling the Seed Service
The seed service exposes a single endpoint/seed that can be called with either GET or PUT methods. It is intended for use in migrating configurations, where adding apps individually would be slower.
Calling the endpoint with GET will return the entire configuration of the Retail Home instance. Calling the endpoint with PUT allows uploading the configuration in the same format.
Seeding Behavior
The general behavior of the seed service is to merge configurations where possible. Most aspects of the configuration can be merged into existing settings. Some items cannot be matched to corresponding entries in the existing configuration however; in these cases the entire set of items will be replaced with the incoming configuration.
The following configurations will be replaced when loading seed data:
  • Application role mappings
  • Dashboard tile states for existing tiles
  • Application filters
All other configurations will be merged with incoming data.
Seed Data Format
The format for the seed data JSON is as follows:
Root
Property (*=required) Type Description
applications
Array
Array of Application objects to be configured
tiles
Array
Array of Tile objects to be configured
dashboards
Array
Array of Dashboard objects to be configured
properties
Array
Array of Property objects to be configured
reports
Array
Array of Report objects to be configured
filters
Array
Array of Filter objects to be configured
Applications
Application entries represent applications registered with Retail Home.
*name
String
Name of the application to display in Retail Home. Must be unique.
applicationCode
String
Unique identifier for Retail applications. If the application does not exist it will be created.
applicationType
String
"JRAF" or "ARAF". Indicates which type of application this is when inserting a new application code. Defaults to "JRAF".
*colorSetId
String
Color set to use for the application in Retail Home. See below for supported values.
*active
Boolean
Whether the application is active. Inactive applications are not displayed in Retail Home.
applicationLink
String
The base URL to the application.
platformService
String
The base platform REST service endpoint for the application.
roles
Array
Array of Role objects the application is available to. Each role object has a single property containing the role name: validRole. When roles are enabled in Retail Home, this application will not be visible to other roles in application navigators after a publish.
Tiles
Tiles define available tiles to be displayed on dashboards.
*tileName
String
The name of the tile to display in Retail Home. Must be unique.
*tileColor
String
The color to use for the tile. See below for supported colors.
url
String
The URL to launch when the tile header is clicked. Supports the <app.url> token when associated with an application, which indicates the tile will open relative to the application's applicationLink value.
applicationName
String
The name of the application this tile is associated with. Must be one of the applications defined in the seed data.
translations
Array
Array of translations linked to the tile. May be empty.
Tile Translations
Translations linked to a corresponding Tile.
*tileName
String
The name of the tile as defined in the Tile object with which this translation is associated.
*sourceLanguage
String
Original language linked to the Tile.
*language
String
Language to which the translation needs to be applied.
Dashboards
Dashboard objects define the unique dashboard associated with a given role in Retail Home.
*jobRoleName
String
The job role the dashboard is for. Only one dashboard can be created per role.
*active
Boolean
Whether the dashboard is active. Inactive dashboards are not displayed in Retail Home.
defaultDashboard
Boolean
Whether the dashboard is the default. Default dashboards will be preferentially displayed when opening Retail Home.
*tiles
Array
Array of Dashboard Tile objects on the dashboard. May be empty.
*regions
Array
Array of Region objects on the dashboard. May be empty.
Dashboard Tiles
Dashboard tiles define an instance of a tile object shown on a given dashboard.
tileSize
String
How much space to allocate to the tile. Supported values are "1x1" and "2x2".
*active
Boolean
Whether the tile is active. Inactive tiles will not be displayed in Retail Home
*tileName
String
The name of the tile being displayed. The name must be from the array of Tile objects in the seed data.
*tileStates
Array
Array of Tile States to display on the tile
Tile States
Tile states are the individual data views on dashboard tiles. Each tile state refers to reports configured for the application and can show both a tile state and expanded report. Reports are drawn from those already configured for the Retail Home deployment.
*tileStateConfigId
String
ID of the tile state report to display
reportName
String
Name of custom report to display. Mutually exclusive with tileStateConfigId.
expandedReportConfigId
String
ID of the expanded report to display
*active
Boolean
Whether the tile state is active. Inactive tile states will not be displayed in Retail Home
*urlConfigurations
Array
Array of URL configurations configured as data sources for the tile state. No more than one active configuration per report type is allowed.
contentFilters
Array
Array of ContentFilter configurations mapping filters to corresponding tile states.
Content Filters
Content filters are a mapping between filters and tile states. Each content filter associates an instance of a filter to a tile state.
*filterName
String
The name of the filter to apply. This must correspond to a filter provided in the current seed data.
required
Boolean
Whether the filter is required for this tile state. Defaults to false.
Regions
Regions are the additional banner and contextual data view located above and beside the tiles in the dashboard. Reports are drawn from those already configured for the Retail Home deployment.
*active
Boolean
Whether the region is active. Inactive regions will not be displayed in Retail Home
*reportConfigId
String
ID of the report to display in this region
*regionId
String
Which region this configures. Valid options are "Primary", "Secondary", and "Banner". No more than one configuration per region is allowed on a dashboard
*urlConfig
UrlConfig
The URL configuration set as the data source for the region
URL Configurations
URL configurations register the data sources for regions and tile states.
*contentType
String
Type of report this is configuring. Valid options are "region", "tilestate", "expanded", and "filter". Tilestate and expanded are only valid for tilestates. Region is only valid for regions. Filter is only valid for filters (see below)
*resourceId
String
ID of the service this URL configures.
*resourceType
String
What type of URL this is. Valid options are "REST", "FILE", and "LINK"
*url
String
The URL. FILE type URLs may use relative paths. REST and LINK URLs are strictly validated and must contain a protocol if they do not use replacement tokens (details below). Replacement tokens are only supported for tile states.
*active
Boolean
Whether this configuration is active. Inactive URL configurations are ignored by Retail Home.
Properties
Properties are used to turn on/off specific functionality on Retail Home.
*propertyKey
String
Key defining the Retail Home functionality. Currently "oracle.retail.apps.retailhome. settings.appNavigator.enableRoles" is used to Enable/Disable Roles flag on 'Application Navigator Setup'.
*currentValue
Boolean
Whether this configuration is enabled.
Reports
Reports are custom reports configured using templates in Retail Home.
*reportTemplateId
String
ID of the template for this report.
*reportName
String
Name of the report.
useLightBackground
Boolean
Whether to use a light background when displaying this report in a tile state. If false, the background will be drawn from the color set of the application.
*parameters
Array
Array of report parameters configuring this report. May be empty.
Report Parameters
Report parameters are used to configure the template of a custom report. The available and required parameters depend on the template being configured.
*paramPath
String
ID of the parameter in the template
*paramType
String
Type of parameter. Valid options are "text" and "boolean".
*textValue
String
Value of the parameter as a string.
Filters
Filter objects define filters associated with applications.
*applicationName
String
The name of the application this filter is associated with. Must be one of the applications defined in the seed data.
*paramName
String
Name of parameter. This is appended to the REST call along with the value.
*filterName
String
Display name of the filter.
*filterType
String
Type of the Filter. Value options are 'MULTISLCT', 'TOGGLECTRL', 'NUMINPUT', 'CHECKBOX' & 'RADIOBTN'.
*active
Boolean
Determines whether this filter is active.
*urlConfig
Object
The URL configuration set for this filter.
options
Array
An array of filter options
translations
Array
An array of translations for the filter
Filter Translations
Translation objects provide localized strings for filters for a given application
*applicationName
String
Name of the application this translation is associated with. Must be one of the applications defined in the seed data.
*paramName
String
Parameter name this translation is associated with. The paramName must be defined in the filters block.
*filterName
String
Filter name this translation is associated with. The filterName must be defined in the filters block.
options
Array
An array of translated options
*language
String
*sourceLanguage
String
Original language of the base filter
Filter Options
Filter options store selectable options for filters that rely on a preset list rather than pulling options from elsewhere
*optionName
String
Name of the option to display in the UI
*optionValue
String
Value of the option to use when sending data
*displayOrder
Number
Order to display the option in the UI
*language
String
Language to which the translation needs to be applied. Not required for options on the parent Filter object.
*sourceLanguage
String
Original language of the base option. Not required for options on the parent Filter object.
Internationalization
Internationalization is the process of creating software that can be translated easily. Changes to the code are not specific to any particular market.
Oracle Retail Home has been internationalized to support multiple languages.
Translation
Translation is the process of interpreting and adapting text from one language into another. Although the code itself is not translated, components of the module that are translated may include the following, among others:
  • Graphical user interface (GUI)
  • Error messages
The following components are not translated:
  • Documentation (Administration Guide, Release Notes, User Guide, and Security Guide)
  • Batch programs and messages
  • Log files
  • Configuration tools
  • Demonstration data
  • Training materials
Oracle Retail Home supports multiple languages and regional variants, including the following. For the full list of available languages, see the Language dropdown on the Preferences page.
  • Arabic (AR)
  • German (DE)
  • Greek (EL)
  • Spanish (ES)
  • French (FR)
  • Croatian (HR)
  • Hungarian (HU)
  • Italian (IT)
  • Japanese (JA)
  • Korean (KO)
  • Dutch (NL)
  • Polish (PL)
  • Portuguese (PT)
  • Russian (RU)
  • Swedish (SV)
  • Turkish (TR)
  • Chinese (ZH)
